Re: Midas Heritage Insert Snake
When working with volunteers... >.> I'm not sure when they get maintenance due to when I'm working with the company that uses them I'm primarily a lighting guy.
They require maintenance. The most commonly overlooked is checking the machine screws that hold the pin blocks. If they get loose the pin block will not fully disengage when the retracter bail is pulled back. If it's really whacky you'll have to disassemble the connector body.
30 seconds with a small screwdriver every 6 months will prevent this.
The other failure modes seem to require brute force combined with abject silliness.
