[FS] miniDSP 10x10 HD + XLR connection plugs = €600,- (Digital Sound Processor) 19"rack format
Oct 1, 2022
5
Zandvoort, The Netherlands
Never used miniDSP 10x10 HD + XLR connection plugs = €600,-
miniDSP 10x10 HD is a versatile multi-channel Digital Signal Processor (DSP) for analog and digital audio sources. Combining high quality audio algorithms along with a flexible graphical user interface, the 10x10 HD can be used for multi-way speaker processing or multi-channel equalization (e.g. 7.1 processing). With balanced & un-balanced audio I/O, the platform easily fits the needs of most audio systems. The sturdy powder coated steel enclosure, brushed aluminum front panel and removable rack ears is a perfect match for both consumer (Home AV) or commercial (ProAV) applications. On the processing side, the platform ranks high on versatility thanks to our unique product concept of audio plug-ins. The unit is easily configured on Mac/PC machines from a responsive and intuitive Graphic User Interface. Once the unit is programmed, control of presets, master volume and digital source selection can be done via the front panel encoder or Infrared (I.R) receiver without the use of a computer. Finally, the miniDSP experience isn’t just another audio product. It’s about joining the ranks of a large audio community with fully integrated tools and extensive application notes. At miniDSP, we value partnerships and the complete integration of our products with well known platforms such as Room EQ Wizard (REW) software is yet another step to provide fully integrated solutions to our customers.
Hardware  172MHz - 28/56bit DSP path  24bit ADC / DAC  114dB SNR ADC IC & DAC IC  Balanced/Unbalanced analog Inputs and Outputs  SPDIF/AES-EBU/Toslink Input with Sample Rate Converter (ASRC)  SPDIF + AES-EBU + Toslink output External control  Front panel volume control through rotary encoder  I.R. remote control for Master volume control and preset recall Software Control  USB 2.0 interface  Plug&Play - No driver required  WinXP/Vista/7 & Mac compatible  Firmware upgradeable for future expansion Power  Single external universal 12VDC power supply Applications  Multi-way speaker processing  Audio processor  Mobile Audio
