Charlotte, NC – June 2019 – InfoComm Booth #6361… Neutrik USA, the leading supplier of robust and reliable professional connectivity solutions for audio, video, and data, is pleased to announce the new 2-in, 2-out NA2-IO-DPRO Dante Interface. The NA2-IO-DPRO features two inputs switchable between Mic, Line, and AES/EBU signals plus two outputs switchable between analog Line and AES/EBU. Two Dante ports provide for either redundancy or device daisy chaining. With its small size, metal construction, and removable rubber protector, the NA2-IO-DPRO offers a rugged, reliable solution that is well suited to a wide range of applications.
The NA2-IO-DPRO front panel provides two latching XLR inputs plus two XLR outputs. AES/EBU operation is seamlessly and independently auto detected for inputs and outputs. Using Neutrik’s free DPRO controller software for Mac or PC, +48 V phantom power can be applied; microphone preamplifier gain, pad, and high-pass filtering can be set per...
Continue reading...
