I'm at a multi-day event, using my new QSC PLD amps. 3 PLD 4.5's rocking the mains for the last 3 days in 90+ degree heat, no issues. Watching the thermal level, and they got up to about 50 degrees C at the peak, averaging less than 40. The manual says they will start limiting at 69, and shut down at 80. That's a LOT of breathing room. They seem to run MUCH cooler than the 4 PLX3602's I was using last year.
Well, now to the stupid. I have a 4th amp, a brand new PLD 4.2 that is being used as fills. The amp was working just fine, but when I tried to monitor it with Amplifier Navigator, it said it needed a firmware update. No big deal. I waited until everything was done for the day, and ran the firmware update from my mac. Everything started fine, but then, uh oh, Update error showed on the mac, and the amp was DEAD. No lights, no display, nothing responding. It didn't show up in the amplifier navigator. Gah.
It was late, so I just swapped it out with the PLX3602 that did the job last year. Of note, the 3602 runs noticeably warmer than the new PLD amp.
Anyway, I had some time, so I did a little research on the dead amp. QSC does have another update utility you can use to update the amp if the update fails. The catch is, the updater is Windows only. Ugh. Well, I happened to have Parallels installed on my Mac with Windows 7. The update utility recognized the amp, and was able to upload the firmware and the amp fired back up to life.
The firmware wasn't necessary, but I wanted to be able to monitor the temperature, especially since this is the first real test of this amp in an outdoor show. In the end, not a crisis, but had I not had a spare ready to go, it would have been a lot more stressful.
