Re: New Danley sub
Would there be anything to gain from doing the V-configuration with TH118s, you think? Or is it too small?Also, what would be required from the "roof" material (the sheet you'd put on top of the)? How sturdy/heavy would it need to be to work well? I'm assuming that a roof that vibrates too much would not give the optimal power out of the array? Any suggestions to specific objects you'd use for this?Or you can do a modified version of the exit in the middle 120" wide and make a V out of it. The mouths would be at the point of the V.This does a couple of things-especially if you put a "top" on the V (ie opposite the floor), you will extend the low freq response (due to a now longer horn path), gain SPL (due to a narrowing of the "pattern" 90°vs180°).If you went to 4 cabinets in the V (2 stacks of 2), you would have a very serious output configuration.
