Hey guys,
although we never designed speakers by our own (we mainly built speakers with building kits), I´m trying to set up a PA System with Hi-Fi qualities together with 2 friends.
"Unfortunately" we decided to go with Pro AMT´s from Mundorf, precisely the 197PP27R-7- H (see PDF below) and the Beyma MC700ND series, for testing we bought both, the 10" and the 12" Version. Unfortunately because we found too late Peter Morris´ DIY TOP, which might not have the HF as perfectly clear and precise as the AMT (- they got an absolutely insane impulse response and very low distortion compared to Compression drivers) but seems to be the best solution for a high quality Speaker we found on our long search through the internet.
Now, there are many possibilities for us, and maybe some of you could help us going into the right direction.
We want to try out our own designs for sure, even if it is just for learning - double 10"/ 12" in MMT (MTM seems not to be an option as it´s not possible to arrange the two Mids even near half the Wavelenght for a crossover to the the AMT)
Therefore we would also build the double 10" design from Jaroslav Mikyska from the "Double 10 and Horn" Thread to see which fits better for our application (Sound Quality is still a little more important than extreme SPL), and also there, a very low crossover frequency is required
Maybe someone can tell me from the Datasheet of the AMT if it could be possible to go with the Crossover low enough to match the DIY Top, still we will also ask Mundorf what they think (We got the Version with fan, so they should be capable of taking some Watts also in the lower end without burning instantly- but if they do, it would be a lot of money burning)
If there is a chance to use this AMT in the PM Top, that would be absolutely perfect of course, even if the AMT might be the limiting factor in SPL then...
Let me hear what you think about our plans, and what design you would suggest for our application / Speakers
Thank you all in advance for your help!
Cheers, Moritz
(I´m not sure if the attached pdf works- it would be page 19 of the following link http://www.mundorf.com/PDF/MUNDORF_proAMT_Catalog.pdf)
Cheers, Moritz
