In my experience, an all powered monitor setup works incredibly well up until a certain level of event, at which point you're probably going to be deciding between one of the big boy monitor solutions anyway. For the levels of events, including festivals, where a 12" two-way cabinet is more than enough, powered boxes are an excellent solution. They are quick and easy to deploy, sound good, and aren't any more expensive than a passive solution. The best part, however, as that they are typically great utility loudspeakers which can be used for PA at weddings, on smaller stages as mains, and many other things. I, personally, am not a big fan of 15" boxes as much as a good 12" for this kind of utility box, but to each their own.
Ultimately, I think they key thing to remember is what you're going to be using them for. If they're just monitors, and only monitors, and that's it - go specialized, passive or powered boxes. However, if a utility box that can be used for monitors is more what you're looking for, a powered cabinet is the way to go.
