[FS] Powersoft Amps, DC-One, Cases
Mike Pyle
Santa Rosa, CA
Following used equipment for sale. Low hours, excellent condition. Add shipping from 95407, and sales tax if you are in California.
1 - Powersoft K6 amp basic model............. $2600.
1 - Powersoft Q4002 amp......................... $1300.
2 - Powersoft Q4004 amp......................... $1600 each.
1 - EV DC-One processor.......................... $450.
2 - LM 10u amp rack cases, deep for PS amps.... $400 each.
Re: Powersoft Amps, DC-One, Cases
Mike,
what is the depth from front to rear rail on the racks?
Scott
Rail to Rail is 21 1/4". Rail to lid is about 25 3/16". Lid to Lid is just over 29".
The amps installed in these had the power cords modified using right angle shells for the AMP connectors, otherwise the stock Powersoft cords would have required more depth if left connected to the amplifiers. The case pictured below has a full caster board that extends under the lids. The other case has a shorter caster board with rubber feet and uses quick detachable caster mounting plates. They were built as a pair with the idea of removing the casters from the second case to stack them.
