hi,
do you know anyone who makes ready made patch panels that go to/from xlr and some multipin connector?
CBI
Guitar Cables, Audio Snakes, Video cables, Lighting cables, Pro Sound
BRTB
BRTB Canada || Our Catalogs
Not sure where you are located, but contact either of these two - they will make whatever you want....
Are you wanting 32 XLRs and a corresponding multipin on the panel? Or 32 LXR on the panel to a multipin pigtail on the rear? or a multipin on the panel to 32 XLR pigtails on the rear? I've seem panels with 32 XLR in 2RU but it doesn't leave much room for a multipin.Ideally want something rackmount, 2U, 32 xlr on one side, multipin (?) on the other.
Not if you've already got 32 XLR connectors in there…besides, if you know that "you can get 2 or more multipin connectors on a 2u panel!", then what do you need our help for?Sure you can get 2 or more multipin connectors on a 2u panel!
I know this is my first post on this forum, but I've got to ask why the tone to this response? The OP question was did anyone know a good manufacturer; perhaps he doesn't have time to make his own, or wanted to see if there was a less expensive alternative to the whirlwind custom shop...
That said, personally I would wonder about the robustness and quality of a ribbon connector if it is going to be deployed in any kind of touring or event situation...
Because you asked for something that is impossible to make. A PANEL only has so much real estate. 32 XLR's will fit, but nothing else will be going on that panel. Plus, it will be as limp as a football bat.
You can have 32 xlr's mounted in a rack mount CHASSIS with your choice of mult on the backside. There would be plenty of room for 2 or even 3 mults if this is to be a splitter.
If you are intending to fit 32 XLRs on a 2U panel, don't expect it to be easy to plug or unplug them. It physically fits but it's a huge pain.
