These have been out for a bit, is anyone here using them? I'm looking at the 4.5. Any comments? Do they work well on subs as well as full range? Looks like a good package on paper, but reliability is a concern.
Thanks!
Matt
Thanks!
Matt
Thanks!
Matt
Had a quick look on the QSC site and it all looks fine. They are a big company with a history so hopefully these things will last a while. The one thing I noticed that really makes me happy is that the software is also Mac/Apple compatible - YAY! Maybe now the Crown folks will rethink their PC only software when they start losing sales due to platform preferences.
The "software" is currently just a firmware update and preset backup tool. it doesn't allow you to actually do anything
I don't know how a company can spend the time it takes to produce firmware that does all the hard work, plus a UI but then takes forever to create a control app.
Jason
I've installed a few and quickly replaced them with PL380's. Toasted all of them within days of being installed.
We were one of the first to use these amps over a year ago. Mid shows a few weeks into owning them one of the amps stopped sending output and came up with "Failure" on the LCD screen. We had to send it in and QSC sent out a new one. Fast forward a few months we now had a spare in the rack. Fire up the main amp and none of the mute buttons would un mute. Fire up the spare and the same exact issue. We found out that QSC knew about the issue and released a new firmware to resolve it, but never notified us. Pretty alarming as we are dealers.
All that being said they are a very impressive little amp. We run 1 MTL sub and 1 EV QRX212 a side off of one amp and it sounds great and has more than enough power for our application. We have put the amp against the new Lab Groupen 1 space 2 channel amp with "lake processing" built in and this QSC not only sounded better, but had a good bit more headroom.
We have been using the newest of the PLD amps we own all summer long non stop without issue. I feel like QSC has finally gotten all the kinks out of this amp.
AHA! Now we're getting somewhere - someone who owns and uses them. So what's up with the software? Is it merely a firmware update as Jason said or is it a full featured set of tools akin to what Crown offers? Have you used a Mac/Apple to make presets with various functions??
Failures within days sounds like a combination of inadequate protection within the amplifier, and grossly inappropriate application. What were you doing with those amplifiers?
Subwoofer applications for both failures. First one we were goofing around after finishing up an install- running some sine sweeps, fairly hard down low and the amp just plain went poof. Shot a nice flame out the front. We were averaging peaks of -10 on the meters. Second failure I was not present for. It was installed in a restaurant/bar, running a pair of dual 15" subs. Guy said the subs started sounding really funny during the "first DJ set," and then they just stopped. Amp wouldn't even turn on.
I think people are misinterpreting what these amps actually are. They are the PLX amp line, but with DSP and 4 channels inside 2RU. If you don't see a PLX amp working for your application then I doubt the PLD will work.
