QSC TM30 recording issues
rob henry
2
australia
  • TM30 Works perfectly until i try to record digital audio ( backing tracks live using ableton ) as soon as i select MULTITRACK USB in recording mode it disables digital input, sometime removes the digital input button from the track altogether, but disables all incoming digital from the desk , analogue signals are still present. Basically means i cannot record a performance at all, using SAMSUMG T7 SSD, formatted to fat32 using the desk itself.
Strange issue, any ideas? Anyone encountered this on any other digital desk?
It is not uncommon for USB multitrack and USB computer connection to be mutually exclusive (this is also the case on the A+H SQ series, for example), although QSC isn't as explicit about that behaviour in their documentation as A+H is.
Hi, i guess that is the answer, someone suggested i use an interface to send the tracks to my desk as audio rather than digital as you can do one or the other but not both, the recording mode over rides input mode, i think. Thank you for the help.
