So I bought a whack of RADIAL PRO DIs thinking I'd be much happier, when in fact they are often more troublesome and I end up using an active DI.
This defeats the purpose of having a passive DI so when the muso forgets to ask to unplug.
About 2/3rds of the instruments I plug into them requires more than normal gain to get anything from it. Is anyone else experiencing the same problem with weak output from these di's (and no the pad isn't engaged). Is the only solution to use an active di, or is having a higher than normal gain an issue?
thanks
thanks
