Re: Restaurant audio System
your chosen speaker wire is not plenum rated. if you've run it in any ceiling spaces (which I assume you have based on your speaker choices) then you've violated fire code and could release toxic smoke into the ventilation system if there is a fire
"in-wall" is different from "in-ceiling"
Just because it works doesn't mean its done right
do not pass "GO", do not collect $200
Jason
I originally posted this thread asking for advise on how-to install or pick a good 70 v audio system... I received good advise and some really useless ones. I'm an electrical and computer engineer which makes me pretty comfortable with the electrical and digital arenas, but not as much so with the audio, beside the home audio systems. As an engineer, I'm a big believer in the design and planning, hence, my original post. But when I read from the so-called experts discouraging big words (regardless if the sincerity) I became more determined to pursue my plan and find help elsewhere. which I did...
In closing, The audio system looks and sounds really great. It took me longer to put the plan together and order the parts, but it was certainly worth the extra days.~:-D~:grin:
I'm sharing my restaurant design and hoping that someone can use it as a template. God bless.
Jason
