Rivage cs5 and Nexo NXAMP4x4mk2
Larry Heinrichs
2
Portland, Or
First Timer, hoping for some solid intel.
The NXAMP4X4MK2 comes with an interface card labeled remote control. This stock interface card is 48khz 24 bit.
I'm supposed to be able to control the Nexo amp remotely from the Rivage console.
There is, also, a 96Khz interface card (NXD104 MK2) for the Nexo amp so I can keep it at the same "tempo" (joke) with the Yamaha 96Khz bus.
What I can't find is whether or not I still get the remote control of the Nexo Amps.
Does anyone know?
From The Fine Manual:
NXAMPmk2 can be remote control through an Ethernet network, using the default NXRM104 card fitted into
the NXAMPmk2 expansion slot, or one of the optional digital audio input cards, all featuring Ethernet port
for the remote control.
So all network interface cards for the unit support remote control, but not all support audio over Ethernet.
If you use an audio input other than audio-over-Ethernet via an appropriate card, you can still have remote control if a network interface card is fitted, but you will need to run a network control cable.
