Re: Scene Manager - Public Beta Release V 0.1.5
Hi Kevin - thanks - the port you defined will be fine. I will try \xcontrol again - though the behringer OSC doc says timeout 10 seconds - what I did was send /xcontrol and then move a fader immediately but did not get anything back - will have another go. I suppose that Xcontrol itself must be continually polling the X32 I presume by sending /xcontrol,
very very slowly getting a (rudimentary) hang on OSC
Nick
Hi Nick, that's good news that it works ok with win 8 .
Yes I'm using a fixed port of 1024 but it would be easy to change that to a user defined port.
Once I've finished the scene management update I will look at streaming changes in the tester , I've used /xicontrol in the tester before and it worked but you have to send the command every couple of seconds otherwise the x32 stops sending responses (by design)
Kev
Nick
