Re: Small In-Line Pad
Here's an example of a 40 dB pad built into the male end of a barrel adapter, but you could do the same thing if you were careful inside a regular male XLR connector. This shouldn't be used between a line output and a phantom powered mic input because there is a very real chance that you can damage the line output driver. And as JR suggested, it's rather unlikely you would need a 40 dB pad on any microphone, so use Ryan's values rather than these.
GTD
