Is it more efficient to have a larger quantity of speakers with a lower power level or keep current amount of speakers and up the amp size to max speaker power handling capacity?
If you are already at the max size amp for the speaker (and that is NOT a cut and dried number to come up with-LOTS of variables involved-style of music etc) then using a larger amp is just going to guarantee you will be needing more speakers or a repair job.I can run my amps bridged now to my current cabinets or up to double the amount of speakers at a lower power by running the amps in stereo. What would be better?
John
Doubling of the quantity of speakers increases efficiency by 3 dB as long as the output sums coherently.Is it more efficient to have a larger quantity of speakers with a lower power level or keep current amount of speakers and up the amp size to max speaker power handling capacity?
No. THe 6dB comes from DOUBLING BOTH the number of sub cabinets AND the amplifier power. I have never seen a case where you can get 6dB and keep the power the same or "about" the same. It takes DOUBLE. At least as far as I have seen.That is all a little true.
There is something like coupling which can actually increase the SPL level to about 6 Db Without needing a much bigger amp.
Misja
Speakers run near "max power" often have 3 dB or more thermal compression, so four "500 watt" (EIA 426A power rating) subs run at 250 watts each (1000 watts total) may be 6 dB louder than two 500 watt subs driven with 500 watts each (1000 watts total).
Sorry but you get acoustic doubling. That's almost free about 6 Db's. In Subs that is. The world of physic and specifically obstruction makes it so that it doesnt work in real life with frequences higher than about 120-130 Hz or so.
Do you have any proof of this? Or any documentation. If what you are saying is true-then if you also double the power-you would have an increase of 9 dB (6+3).Sorry but you get acoustic doubling. That's almost free about 6 Db's. In Subs that is. The world of physic and specifically obstruction makes it so that it doesnt work in real life with frequences higher than about 120-130 Hz or so.
The amps will run out of juice soon though. But you don't need double te power. If you want to do it right though just make sure the amps can take te load.
HOWEVER simply adding a second sub and keeping the power (NOT the voltage) the same to the "system", then I will have to have a lot more convincing to believe that you get 6dB.
Any source of information would be appreciated.
EXACTLY. With the same voltage applied-the power will double when you half the impedance by adding another loudspeaker.I think Misja might be forgetting or unaware that when you double up the number of subs or any type of speaker with true coherent summing on the same amp, the amount of power delivered by the amp doubles up to the point of clip. This is due to twice the current being supplied to the load from the halved impedance of that load vs. half the number of boxes. So yes, you'll get 6dB more with double the subs on the same amp *until* the point where the amp runs out of gas. And of course, the amp will clip at a lower voltage level than before due to current limiting from the drop in impedance, yadda yadda yadda...
