The System consists of a Behringer X32, 2 Behringer S16 digital stage boxes, 150' of Horizon Duracat Cat5 cable.
Rewind back to a cold New Years eve night Dec. 31 2012. We had a double stack JBL VRX system powered by a pair of Crown XTI6002 power amps. Providing for one of our regular bands in a ballroom at a local hotel that we had just spent the week prior to that with a large christian group in the same room. The system we provided the week prior was almost the same system but with a analog Ramtech snake system. We loaded in around 5PM on NYE and I decided to try our new Behringer S16 stage boxes that we just received. This decision was made based on the current floor plan of the room it forced us to run the snake overhead and the Duracat cat5 cable would be much easier to fly than the 54 pair Ramtech. Everything went smooth as usual and we had our setup completed with in 45 minutes. Once FOH was set I decided that we should take a listen to the system before the band arrives. When I walked up to the desk I placed my hand on the lower right corner of the desk and ZAP I got shocked by static. Instantly I thought like a always do when my electronics get zapped "I wonder if that hurt the system"? It appeared all was functioning like normal. This scenario played out about 5 to 6 more time while waiting for the band to arrive. After the second time it happened I realized that each time I received a static shock from the desk I would hear a crackle-pop from the speaker system. This happened with all channels muted even the main output fader muted. I chalked it up as a non-issue. But then my stage hand walked across the carpeted stage and grabbed the guitar mic that was patched into the system and muted and then snap-crackle-pop my playback music stopped playing and then reconvened after the static shock was blasted through the speaker system. The best way I can describe the snap-crackle-pop sound is it sounded like a lot of clock jitter. Now for years I have accidentally given my gear a shock or two at a gig and never ever heard it through the speaker system. Now this is my first experience with a digital snake system and I'm wondering if this is a inherent issue with all digital snakes or is this a Behringer issue?
First thing this morning I made the call to Behringer and I was told that I needed to run a power conditioner on both the stage boxes and the desk and that will not happen. I think that is incorrect because a power conditioner shouldn't have anything to do with grounding a static charge in my opinion. Maybe I'm wrong. After that call I figured I would call Midas tech support in hopes that maybe they might have seen the same problem and since the companies are related now maybe they would shed some light on the subject. The answer I received from them was "well maybe you should have bought a Midas" literally thats what the guy said. Fun thing I told him I did have a Midas Pro1 and sold it once I took delivery of the X32. Now I'm wondering if maybe he was right.
FYI the FOH desk and the stage boxes where on different AC non gfci circuits in the room. Not sure if that would be a issue or not. Also there is no UPS backup involved.
If anyone has any thoughts please lets hear them. Until then Ill be in my shop with my X32 and a pile of balloons trying to replicate my problem.
