So I got four used packs, and I'm currnetly going through them. Some channels have issues, and I was wondering if any repair guru's had any ideas on where to look, or how to test. I have 3 channels that will work only using full on override, and will show fader activity on the override card, but the fixture will not dim. it's full on , or nothing.
Any ideas on what to test for... I swapped a choke on one channel to see if that was it, and I swapped ssr's on these channels, and I tried a different DMX card. Still not responding... I'm thinking it's the ribbon cable that connects the back of the card to the relay section, but when I meter the ssr (on the top of the screws), it shows varied voltage from 0 to 22 volts... as I move the fader....
thoughts ?
thoughts ?
