hey
Yeah just what I was gonna say, room response would be my first guess, either a reflection from the wall or from the floor.
As Mark says try sitting the cabinet on the floor (and away from all other walls etc of course) and putting the measurement mic a meter away from the cab, and as close to the floor as the stand will hold it without touching. You won't get a true measurement of the low end, as you'll be in half space now and be getting a boost in response from the ground, but it will at least let you eliminate a room reflection as the cancellation.
If that doesn't work then yeah it could well be an internal reflection. Even if the overall cab is 814mm high, the 15" section could be in its own closed off chamber inside who's dimensions may be a little closer to the size needed to create an internal standing wave at that frequency.
K
