Hi All
I thought I would just post this little project I did the other day.
I needed a small snare mic and thought I would take the opportunity to have a go at this mod that I had read about.
I did it by simple unscrewing the 2 body halves and desoldering the cable and I have kept the lower half of the body with the transformer in it in tacted so that I can put it back together at a later date if I decied I need to.
I simply used the cone part of a lamp fitting and drilled the end out for a gland an glued the gland into the end.
I soldered the Mic lead direct to the mic and the lamp end just screws on.
Yes I am aware of the dangers of phantom with this mic but it does sound very different from a normal 57 and a lot more like an SM7 and with a level drop that I like as well.
We will see how it goes on the weekend at its first gig.
Cheers
Cheers
