I have mentioned this before in someone else's post sometime back but it has been a while and I thought I would post it again for any new forum members. If you are running a show as a single engineer and you want a stellar board mix this is an easy way to get one and be able to devote your undivided attention to your front of house duties. It requires a decent set of isolation headphones. I use the Vic Firth's because they work well and are relatively inexpensive.
1) Set up a post fader aux mix and put all the levels at unity.
2) Set up your front of house mix.
3) Solo the aux mix in the headphones and make any adjustments such as bringing up guitars that are low in the mix because of stage volume.
Mix your show for front of house. You aux mix will follow your fader moves and be balanced for the feed.
If you have the extra aux sends or a post fade stereo aux you can even get creative with placement. I always bring my effects returns in through channel strips so I have them available in the mix as well.
