Re: to biamp or not to biamp
The real difference will be in how the digital processing is set up. Done right it is a completely different animal as Rob mentioned. It is not just a crossover point and filter slope but also time alignment, some frequency smoothing, and usually some voltage limiting. Also if done digitally there aren't all of the phase issues from the analog crossover. The difference is not subtle. Speakers are the weakest link in the chain so a drastic improvement here is much more noticeable. A little costly when you figure the price of the processor and extra amps and cords but usually money very well spent.
If you are unable to get the the processing done yourself or find a blackbox setting for those cabinets I would say it is worth it to hire someone like Phil Graham to do the set up and also to recommend the best and most cost effective processor. That is almost a field by itself and after over 30 years in sound reinforcement that is one of the few things I still hire out if there are no factory settings for a particular processor, amp, and speaker set up.
