Another question for you good folks.
So I had this rig set up, to 615s, one either side mounted to the walls, quite high up, maybe 4 metres from ground level, 2 618s-xlfs under the side of the stage pointed at the wall. It sounded ok sometimes, terrible mostly, a touring engineer worked some magic with the DSP and it sounded amazing. Then it sounded amazing Without his DSP programming (just running full range). I finally convinced the pub to let me move the subs back out so they would be lined up with the tops (because surely that will be better right?). And it sounds terrible again. At present it's running totally flat so tops are doing full range and sounds like it has no low mids, or mids actually for that matter. Super painful treble, not much bass, kinda sounds like the subs and tops Aren't working together. Every track with vocals sounds like the vocals are buried in the mix when the should be at the front. The question of out of phase does cross my mind but I tested that a couple of weeks ago and it seemed that everyone was all good.
Suppose questions are many fold, can these PRXs even be coaxed into sounding good?
Is the reduction of sub frequency bouncing around (due to being pointed at the wall) worth the loss of volume?
Could it be something other than the speakers that sucks all my low mids out? (Like a bad mic cable, or the DBX drive rack, or the fact that they are very high).
Tomorrow I will go in with a DB metre and SMAART tools and at least try and tune this thing properly with technology (because I've failed to do this by ear). I'm feeling apprehensive, is that gonna cut it? Can the 615s even give me the full range I want and the volume I need? (See other thread for contemplation of increasing it to two a side).
My other thought was that maybe I should bypass every facet of my installation and play something (from a CD, not a bad mp3), through a separate mixer, plugged straight into the speakers, see if that sounds better, work my way back from there.
Soooo not the right rig for the room but with not much cash in the bank, I'm really hoping I can get better sound out of this than I have today, which surely I can, because this time last week it sounded infinitely nicer, and the only thing that has changed is moving the subs into (what is theoretically) a better location. Sigh!
