I have no experience with the VTC tapped horns-but would like to clarify that Tom Danley did not design those cabinets. The technology (ideas etc) are licensed from Danley-but designed by VTC Engineers.Anyone using and liking the VTC 18" tapped horn subs?
The one question I would have with the specs is the statement on the freq response chart. It says 1w 2.8V and it is a 4 ohm cabinet. So either is it 2 watts or the drive voltage was 2 volts.JR -
The VTC (Yorkville) ELS118 is NOT a TH118 knock off, nothing like it. It's one of those basically cube-shaped boxes with a rearward facing driver and some internal woodwork making it a tapped horn of some ilk. IMO it's worth a listen, or better, a bit of hands-on to get an idea of what it can do for the OP. Whether or not it is more worthwhile than the TH118, I have no clue. I own neither of these boxes, I posted as I have heard the VTC and was impressed.
.:: VTC Pro Audio - ELS118 ::.
-Tim T
Another detail just to note is that the frequency response and probably thus also the sensitivity and max SPL are ground plane or half space measurements. That is noted on the frequency response chart but not for the other numbers. Many people will assume additional output from boundary loading without knowing if the data for the speaker already reflects half space conditions.The one question I would have with the specs is the statement on the freq response chart. It says 1w 2.8V and it is a 4 ohm cabinet. So either is it 2 watts or the drive voltage was 2 volts.
No way to know for sure.
Probably for a small sub-set of all customers. The vast majority look at specs for "more is better" or "louder is better" purchase comparisons.One thing that I think is so often "missed" is the whole PURPOSE of specs and measurements. What they SHOULD be telling you or giving you-is an idea of the REAL WORLD performance of the cabinet. This will also allow designers to use those specs and extrapolate SPL at distance and so forth.
We've been around this tree before... Every loudspeaker engineer I ever knew and worked with, complains about the "other guys" distorting specifications.But there are a number (of popular manufacturers) who give very misleading information-and the buying public just "eats it up" and recites it as fact.
Good examples are when a loudspeaker has a large peak at some freq. This is often cited as the "peak" output. While they are not lying-they are FAR from telling the truth or giving USEFUL information about how loud the loudspeaker can get using normal material that the average person would expect to use/listen to.
While this peak may actually be there-the REST of the loudspeakers response cannot get that loud. So the output ACROSS THE INTENDED FREQ BAND (the USABLE output) is much lower than the stated "peak" output. I have seen it as high as 15dB less. And there are a number of products that are 10dB lower-that is quite a bit!
So when you actually USE the loudspeaker and eq this peak down-the loudspeaker is easily outperformed by another loudspeaker whos "peak" rating is actually lower.
Hence the need to provide MEASURED data that is reproduceable by anybody out in the field. If you can't reproduce the specs-then what good are they?
If you have to have a "special test tone" or "special conditions"-then that spec is not of much use in the REAL world.
I like to use the analogy of a cars gas milege. What if the rating was done while coasting down a mountain. You would get a really high number. And while the number is not "wrong" it is FAR from giving a customer an idea of what he can get while driving on a NORMAL highway or around town.
Sorry to rant.
This has no bearing on the subject or products at hand-but rather the "spec game" in general.
I think some manufacturers sit in closed rooms and place bets "Let's see what we can get away with telling the lemings this time". HEY Watch this! I bet they will eat it up.
I have gotten a good start on exactly a paper like you describe-no names-but actual data from the products. I just need to find the time to finish it.I have suggested that maybe you should write an article or AES paper, without actually naming names, but giving real world examples (with mfr concealed) of the excesses you describe. If you arm the consumer with how to recognize actual spec inflation, the sun light should help disinfect it. Consumers do not embrace being fooled. The white paper about "specifications" on your website seems pretty thin (barely longer than this post). Maybe expand upon this discussion there with some hard real, but un-named, examples.
I am not sure it is as widespread as you suggest, while no doubt mistakes and examples pop up from time to time. Peavey has been widely criticized as playing fast and loose with all kinds of specs. That was not my personal experience in my 15 years there. I did see (or hear about) multiple examples of competitors using specification metrics that overstated performance. If Peavey was the odd man out using a more conservative specification, the customers would just ASSume the other value competitors were a few dB louder, than they really were. This is not an excuse, but a practical reality in some market segments. Being right is little consolation when you lose significant sales because of it.
Surely not all of your competitors are cheating with distorted specifications.
I use a design for Halloween that "kinda" resembles the ElS118-except it has a single 15". The performance is pretty good-and a good bit deeper response than a TH115. I only built the 1 prototype. I quickly hated it-moving it around. So it never went any further. We were calling it the "twister" because of the air path.I don't have the time to search, but I thought I'd read somewhere that VTC's ELS118 was a discarded Danley design, after Danley instead developed the Th118. I must have misunderstood whatever it was that I read, but it's stuck in my head as great Danley folklore. Can you help straighten me out Ivan? What sub is it that you put out for Halloween? The "Frankenstein" or something like that? No relation to the ELS118?
I had the ELS118 on demo a while back. If I recall, it was roughly equal in output to 2 Growlers, with lower extension. A great sounding sub, but quite unwieldy to handle.
Is it possible for the consumer to modify the IEC outlet into a PowerCon.
I only ask, because I have plenty of PowerCon cable in stock and it is much cheaper to build PowerCon than IEC.
Thanks for clearing that up-that is news to me.Hi Guys,
There is some incorrect information in this thread (even from Ivan.....) about the ELS118 so perhaps I should clear things up.
First off Ivan is correct that Yorkville/VTC normally licenses Tom's technology and pretty much take the design work into our own hands (by me) with some of Tom's input when necessary, Tom and I have worked together a long time and we have a very good working relationship helping each other and bouncing ideas back and forth pretty regularly.
So let's clear things up...
First this was one rare situation where Tom DID design the ELS118 (and the ELS212 in fact). I was short on time working on the rest of the VTC product line and Tom did the simulations and rough prototype drawings himself and then passed it on to me. We (Yorkville) built and tested the prototypes and Tom was actually here at Yorkville on business when he and I did the final tweaking and listening tests together.
The TH118 was designed much after the ELS118. I have never heard the TH118 or seen the inner details of that cabinet so I don't know how they compare. But I can say that the ELS118 was not a "Discarded Danley design".
And lastly the rated cabinet sensitivity of 105 is correct...the stated drive voltage should read 2V. I will ask the guys to correct this on the spec sheet.
Hope this clears things up.
Cheers,
Todd Michael
Yorkville Sound/VTC Pro Audio
The one I built does go from front to back and changes directions and comes back forward and changes direction again and then comes out. Sounds like the same concept anyway.Ivan,
I don't think the horn folding in the ELS118 is like what you are referring to as a "twister" or "vortex"...I have built several other prototype tapped subs with that layout before and am very familiar with.
The ELS118 has a very complex horn folding going from the front to the back of the cabinet (4 times) in a sort of "W" formation first "splitting" in the vertical direction and then transforming to the horizontal direction. In fact this horn has one of the most complex folding patterns I have ever seen and is a real "treat" for the guys in the woodshop to build. But it's performance is excellent by ANY standard. It was designed for pro touring applications and with it's 2 cabinet dolly most users roll them off the truck into position and never lift them.
T.
T.
