[WTB] Warehouse shelves... know where I can buy more of these:
Re: Warehouse shelves... know where I can buy more of these:
Ok, apparently I need advice on putting up pictures as well...
I tried using "manage attachments" then selected the file and clicked upload... then closed the window.
No luck here.
Advice?
David
No luck here.
Advice?
David
David, there was a place I found in Tewksberry just inside of 495 off of RT38 that had a huge pile of different models of this stuff when I was looking a couple of years ago. I don't remember the name of the place but it was South on RT38 to the traffic light after the Walmart, right at the light and bear right and up the road a little bit.
David,
You then need to insert the image you've attached if you want it to show up pretty.
I actually added the picture in for David this afternoon. Found a bug (or weird Northeastern network block), but from IE on Win 7, I couldn't double click this picture to make it normal (medium) size from the thumbnail view.
But to insert a picture, click the image in the toolbar:
Then you can either select an image to upload from you computer, or click the URL tab, and upload one to our server from an outside URL.
I've never had the toolbar above. I always assumed it was an IE9/Safari incompatibility, but decided to check my profile. Somehow I was set to "Basic Editor", which meant that I had to manually type in the code for attaching images, etc. I don't recall ever setting that setting, but I'm glad I found it and changed it to "WYSIWYG Editor", which now gives me the toolbar. The setting is under "General Settings".
Sorry for continuing the thread hijack.
Check your local craigslist...most cities seem to have an industrial liquidation company or 6 that post constantly on there with these units.
