Last night my trusty AT 3035 was unusable. It hissed like a cheap AM radio between stations. It passed a little audio but not much. My first thought was the mic cable so I swapped that out. No change. So I took the mic apart and checked for anything odd. It looked fine so I killed the phantom, plugged it in and turned on the phantom. It worked find for 20 seconds or so before the hiss came back. I tried a different channel on my mixer, same problem.
So I swapped the mic for an ancient Oktava MK102 and that was fine. A friend brought a Shure SM27 and that was fine. We ran with the Shure for the night.
Strange thing is, after the show, I pulled my spare AT 3035 from the truck and it hissed the same as the first one. I grabbed my cable and mic and plugged it into the house board and it was fine. We left it on for a while without a problem.
So it must be the phantom on my board. My question is, why would the Shure and the Octava work. I believe the AT 3035 and the MK012 are both electret and the Shure externally biased so that wouldn't be the problem. I'm guessing it has something to do with the voltage needed by the phantom for the three mics. Any ideas?
