Re: Whats wrong with this mix?
Jordan is actually spot on if I understand him correctly, but he's saying it differently than I would: If a performer "works the mic" there is less need for compression. Most peole think of compression as a phenomenon that reduces peaks, whereas it's actually just as correct to say that compression raises the level of background noise.
Gain doesn't change anything. The ratio of voice to everything else would be the same regardless. Singing louder will make bleed less apparent because the ratio is higher.
