Hi:
I'm new to the forum and purchased an X32 just a few months back and am trying to get up to speed on using this as an audio interface for mixing. I currently use Logic Pro X and am confused about the routing and/or set up for routing 4 different headphone mixes. I have things working fine for the input signals from the mixer to Logic, and playback into the Aux Ins from the Card 1/2 paths. And I have set each track in Logic Pro with 4 different buss mix's (one for each Headphone) to create the individual mixes from Logic to the Aux outs for each headphone monitor. What I am confused about are two things: What do I need to do on the routing page on the X32 for this to work properly? And what are the outputs that I should be selecting from on the Headphone Aux outs? Do I need the X32 edit software? I currently just connect the X32 to my MAC with a USB connection and do not use DAW integration or any X32 software.
I also do want to mention that I have a 4 channel headphone amp with individual inputs / outputs with volume controls. So i have the hardware needed. What I lack is the understanding to figure out the wiring and protocols.
As an FYI I could be doing this completely wrong and am happy to make any changes needed to get this working properly. I cannot seem to find specifics online for this particular question so thought I'd join this forum, so any advice will be sincerely appreciated.
Thanks in advance for your assistance.
Best,
Mark Kesson
Best,
Mark Kesson
