Thanks for the replies. We have ordered the XR 16, looking forward to the automixer function.Installed an XR18 in a local club and bought one for myself as well. Both have been working well without incident. Both systems use an external WAP for better wireless performance. The XR18 in the local club got its baptism by fire by basically running three days straight handling sound for 40 bands in a weekend. YMMV.
My XR18 has been bullet proof for a year, I love it. If you click on the meter tap in the android app it will show gain reduction for every channelI did my first show with the XR 16 last night, using it as an external automixer. It worked very well.
The iPad app is useless as the automixer feature is not included. The Android app is too minimal, no indication of gain reduction. The PC app wins, very good.
Mick Berg.
I'm not findng it. I see gain reduction for the compressors, but not the automix. Can you explain further?My XR18 has been bullet proof for a year, I love it. If you click on the meter tap in the android app it will show gain reduction for every channel
You don't see gain reduction for the gates? I would assume that is what the automix uses?I'm not findng it. I see gain reduction for the compressors, but not the automix. Can you explain further?
Mick
No it doesn't. At least it had better not as it is described as Dugan style which does not use gates .You don't see gain reduction for the gates? I would assume that is what the automix uses?
My XR18 has been solid so far. I've had it for almost a year. I'd expect better reliability due to the lack of moving parts. Only one knob and one switch. As long as the PCBs are decent and there are no thermal issues, it should stay reliable. The only caveat I've run into is the built in WiFi is very poor. Ever since I switched over to an external Apple Airport Extreme, I've had no wireless control issues using iPad. I still keep a touch screen laptop hardwired to the router at all times though for backup and access to some features that aren't in the tablet apps yet.
The B-boyz implemented a gating function as well that always leave the last mic that was being used open when it is enabled. This is only in affect when no one is speaking.No it doesn't. At least it had better not as it is described as Dugan style which does not use gates .
Mick
Mick
Does anyone have a sense of the reliability of the XR 16? My boss is wary after our x-32 died.
Mick Berg
?Well Dugan does that too. I'm fed up with all this bickering, I'm unsubscribing.
