The band I work with is looking to sell its current FOH PA.
Yorkville Elite/Crown XTi Racks and Stacks
2x - Yorkville Elite ex1000 - these are dual 15" plus 1" HF driver. The predecessor to the E215/E2152. NL4 and 1/4" inputs and have built in crossover or can be bi-amped.
6x - Yorkville Elite sw900 - single 18" horn loaded subs. These are an older version of the LS1208. Four of these have the original (B&C I believe?) drivers, 2 have been replaced with Peavey black widows. All have NL4 inputs, some have additional 1/4" inputs.
1x - Crown XTi 2000 - power amp for tops.
2x - Crown XTi 4000 - power amps for subs. I normally only run 4 subs, 2 per amp bridged at 4ohm. I have run 4 on one amp before, 2 per channel at 4ohm per channel and it worked well. If i keep these I'd probably get another XTi 4000 though for the 3rd pair of subs.
1x - 6U EWI amp rack - no casters, just simple rack. Plenty of NL4 and 1/4" speaker cabling for different setup options. (side stacks, all center subs, etc.)
These speakers are all from around the late 90's, so yes they look used. Rat fur is coming off in places, some scratches on metal grilles, corners, etc. I've been contemplating pulling all the carpet off and painting or putting some sort of coating on them. These are still some very good sounding boxes though. I would say they are somewhere between the MRX and SRX lines from JBL, and probably closer to the SRX. The 2 tops and 2 of the subs we bought brand new. The other 4 subs were bought used and added 2 years ago. Some of the input connectors have been replaced on these 4 subs but all work. I also have the Yorkville P1000EX processor for these (don't use it though) and will include it, assuming I can find it.
$3300 firm
$3300 firm
