​​​​​​​Allen & Heath Qu-24 Mixer with Road Case
Rob Bernstein
66
Framingham, MA
Local sale outside of Boston, MA
24-channel Digital Console with 25 Motorized Faders, Total Recall, Parametric EQ, Touchscreen Control, 5 Cores of ARM DSP Processing, 4 Onboard FX Engines, and Integrated Multitrack USB Recorder.
In excellent condition, only used for a handful of shows, always kept in the road case (included in the sale).
P-Touch labels by the Soft Keys can easily be removed (have them there for quick access at-a-glance).
Only selling because I use my Qu-16 for the majority of my shows and this is not getting used enough to justify keeping it.
I can deliver to any location within an hour of Boston or you can demo it here.
$2000
Allen & Heath Qu-24 Digital Console Features:
▪ 24 AnalogiQ total-recall preamps integrated with DSP for optimum transparency and gain accuracy
▪ Ergonomic layout and workflow is comfortable, fluid, and intuitive
▪ Color touchscreen and dedicated data encoder give you quick and easy access to all settings
▪ Key processing tools are presented clearly on the SuperStrip, with 1 function per physical control
▪ 25 automated, motorized ALPS faders (24 arranged over 2 layers) speed up and enhance your mixing
▪ 4 groups give you subgrouping flexibility to LR for level masters and/or processing
▪ Total recall lets you save and recall scenes (snapshots) at the press of a button
▪ Onboard studio-grade dynamics and FX algorithms derived A&H's iLive pro touring series
▪ Built-in interface streams multitrack audio to/from your Mac (OSX class-compliant)
▪ Plug-and-play with any DAW supporting Core Audio, including Logic, Cubase, Reaper, and Pro Tools
▪ Qu-Drive delivers 18 channels of 24-bit/48kHz recording/playback to/from your USB hard drive
▪ 5 dedicated cores of high efficiency ARM processing provide state-of-the-art processing
▪ Optional Qu-Pad app frees you to tweak monitors and PA from your iPad, onstage or around the venue
▪ Fully compatible with A&H's ME Personal Mixing System
▪ dSNAKE port lets you connect to a remote AR2412, AB168, or AR84 Stagebox via Cat 5e digital snake
▪ Matrix adds 2 further stereo outputs equipped with full processing to the console's extensive I/O
▪ 18-gauge, cold-rolled Zintec steel frame delivers strength, rigidity, and distinctive looks
More images here:
