I've done PET sleeving on several smaller looms, but I'm about to build a snake with 3 CAT6 runs and a 14/3 in it that will be 250 feet. Has anyone ever tried to do such a length before? and are there any tips or tricks?
If the load is 4.75 amps, the voltage will drop 5%, leaving 114 volts if you start with 120. Don't plug in any air conditioners or coffee makers ;^).The load on the other end is minimal.
More than 5% voltage drop from the service to the load is against the NEC. Not that it matters, but still.
I'm preparing to loom my 12/3, 5x Cat5e, 2x tieline snake (100'). Having done a 25' before, there's no way I'll do it again without the proper tool. What a pain in the butt! I've found the proper tool (http://www.techflex.com/land_cuttinstltools.asp), & from my google searching, its prohibitively expensive unless you plan on doing ALOT of looming to make up the investment. I'm trying to come up with a DIY solution since this is pretty much of a one-off. Any ideas would be appreciated.
John,
Funny, I was talking about this very subject all week. I just had a touring artist bring a cat 5/6 bundle with TechFlex, and it was slick. My worry was once that got dirty, how would you clean it? Are you just using tape and heat shrink? Is that easy to wrap? Do you feel you need better protection ?
We were thinking a single 12/3, and at least 4 cat 5e/6- 2 STP and 2 UTP, and possibly 2 combinations (indoor / outdoor).
I know I may take some heat for this next comment but I would not run the power in with the catX cables. 250 is a long way and we do not let power that close to it in cable trays for a few reasons. Just saying. Also up it to 12ga.
Pretty much every tour out there has a long power cable taped to copper drive lines, network cables, and/or some sort of digital audio snake. Installation in a tray may be one thing, but for portable applications it's perfectly serviceable.
While I'd normally agree with the wire gauge comment, the OP's use is such that the intended AWG is fine.
Yup. Very common to see multiple CATx lines bundled with a 10/5, 120/208v 30 amp service to FOH. Nary a problem, but we're not doing networking on an enterprise scale, which I think is Glenn's background.
