Apple Airport Express + DSP
Re: Apple Airport Express + DSP
And you can quite easily set the lease time to be far longer than any show, therefore eliminating any renewal attempts mid-show.
What if there's an issue and it surfaces during the next show?
Hmm - the luxury of not paying attention to a few details with an auto-configuration service and some eventual random hard to troubleshoot failure vs. the certainty that the equipment will work the same way every time, and if there is an issue it will be discovered the first time the equipment is used.
I know which one I prefer, and for mission critical stuff auto-configuration protocols have no place!
Sure, you probably have gotten by for years, and you may continue to do so. Still doesn't mean it's smart. I've had friends and even I myself didn't pay much attention to backups on my computer - until I had a disk go bad and I lost stuff.
It's the same reason you carry insurance. Not because you think it's going to happen, but just in case it does.
As for being a sound guy and not a network guy - there's a recipe for disaster. If you are going to rely on a technology, you need to at least take ownership of the most basic fundamentals for it. Were not talking mastering BGP over multi-homed redundant ISP connections here! It's friggin TCP/IP 101 - IP address, Subnetmask, gateway. Three pieces of information. How about introducing some standards. Standard networks - eliminates the subnet and gateway issue. Label your equipment. Eliminates the IP address issue.
Wow - that was hard. Yup, it may add a minute or two to your device setup - I'm sorry, I thought some of you were professionals? I may be amateur and part timer but I certainly understand the value of eliminating variables to further total system stability. Especially for something so trivial as to be completely laughable. As alluded to earlier, this is more a failing of process control on your part. The best way to experience predictable results is to have well defined processes - this simply becomes one more item in your process.
Good luck - I doubt you will change; you've already indicated as much. I just hope for your clients sake when one of those variables does pop up it and bite you in the ass that it does so during a sound check or some other non-critical time. And yes, I realize that there isn't infinite resources and an incremental cost to each step; I'm not being totally glib even if that's how I may appear to you. But trust me, DHCP issues are NO fun to track down when you have a couple hundred users staring at you, a wired network and a protocol analyzer. If your a sound guy in front of thousands of people with wifi and other crap in the mix too - like I said, I'll gladly shoulder the "burden" of "managing" static IP's for the overall stability. Think about your chief complaint for a moment - an issue with system setup. If there IS going to be a problem, quite frankly that's exactly when I would want to deal with it.
It comes down to the point that understanding networking basics is a requirement if you are going to be doing any configuration of network devices. When you build a rig to go out, using Static IP addresses is going to be more reliable than DHCP, but at the same time, if you don't know networking, and you want to add in another device, you are screwed. Kind of like sending someone out with a PA system, and then a cable goes bad, and they have no idea how to troubleshoot for a bad cable. (yes, that does happen)
The fact that many people have trouble figuring out how to assign DMX addresses to devices makes one realize that expecting them to understand networking basics is kind of a long shot. So, if you don't know what you're doing, leave EVERYTHING on auto discovery. Don't mess with IP addresses. If you need to, take a networking basics class so you understand the concept. The necessary basics shouldn't take more than a half a day to learn. If you need to integrate your system into an existing network, it can get a bit more tricky. At that point, it may be more economical to hire a consultant, versus trying to learn everything on your own.
Oooh, Eric, I don't think that sophomore status of yours allows you to be quite so smarmy and condescending to this group of folks (or anyone else, for that matter, but the rest of that is your cross to bear)...
I don't disagree with the premise of your post, but I can think of a dozen pros on here that have said virtually the same thing you did without being an asshole about it (as well as volunteered their time to answer a lot of probably stupid questions about networking and they were only too glad to do it).
Somewhere, you'll learn that every profession involves communication skills. While yours seem sufficient enough with moving bits and bytes, some human interaction communication skills will (hopefully) do you a lot of good.
Geri O
