Hello, I am contacting you because I have a problem connecting a DSP (BLU-50) to the internet. I have almost no knowledge of music but good network skills. I tell you what I want to do
I would like to access my DSP to cross the internet in order to modify the remote settings. I use the "Audio Architect" program.
I encounter the following problem: I can't find any way to connect this damn DSP in the program.
On the network side, I think everything is ok, I attracted a fixed IP to the DSP, and I assigned it a redirect port in TCP and UDP.
So I'm a bit stuck.
So I'm a bit stuck.
- Can I connect this model of DSP to the internet by plugging it directly into the modem?
- Does Audio Architect allow you to connect to a DSP other than locally?
Thank you for your answers
