New Found Glory’s Chad Gilbert Collapses Onstage After Electric Shock - Music News, Reviews, Interviews and Culture - Music Feeds
I'm wondering if he was using vintage guitar amp...
As Bill Whitlock told me years ago "There is not a judge in the country who wants to hear how the buzz went away-when somebody died because of a shock".Yeah, most of the time that I've seen live voltage on mics is because of a piece of miswired gear that has had the ground plug removed or defeated. The If the ground pin is connected, you get system buzz, or worse, so the solution to 'fix' the problem is to simply lift ground.
That's why that's never an allowed solution for my shows, even if it's 'safe' to do so.
Chad said:Looks like he's using relatively modern gear: New Found Glory - Chad Gilbert Guitar Rig Gear and Equipment.
There is a small thing that looks like a pen that contains a lamp/led.
If it comes close to live mains voltage it will light up.
It's a cheap insurance!
Chad said:
"In between songs I grabbed the mic to speak and when I did it felt like I couldn’t let go. I was being shocked and it froze me in place and when I was able to release my hands off of the mic I collapsed."
Guitar players (or their roadies) need to get in the habit of touching the end of the high E string to the mic without touching the strings of the guitar, looking for sparks and / or noise, if either are present they need to figure out why.
If no sparks, or noise, touch a string with one finger and the tip of your little finger to the mic, if no shock then try holding guitar strings and try touching your lips to the screen to check for voltage.
To tell the truth, I used to use a VOM to test for faults, but getting a good connection can be difficult on some microphones, but my lips can detect those stray currents quite well, and more reliably.
The guitar rig may not be at fault, miswired AC is unfortunately common, and that fact means unless you use wireless mics or a guitar body pack, always check the voltage between the strings and the microphone.
The NFG guys all use well maintained gear in good working condition. It's no surprise this happened at Chain Reaction... That place is a nightmare. Wouldn't surprise me if half the outlets on stage were miswired...
Complaining to the managers for months never got anything done so at the end of the night I got a screw driver and removed all the outlets and left bare hot wires hanging out of the wall on all the outlets near the band area. Wish I could have seen there faces when they noticed the next day :twisted: and yes they finally hired an electrician and the problem went away.
When wires are hanging out of the wall you know the wiring is bad, when bad wiring hides behind the outlet, you have no idea until you check it or get shocked.If you really did that, you set yourself up for a huge liability issue if someone was shocked/electrocuted from hot, uncovered wires hanging out of the boxes. I hope you're just joking. As egregious and dangerous as the club's complacency was, the wires weren't hanging out of the wall.
Aha! Now we're getting down to the real nitty-gritty. In the bad old days we had a regular Monday night jam that we hosted and the outlets were so old and lose that the plugs would often fall out of them. There was always a shock ranging from tingle to a good zap on the lip and one night after being hit one too many times I lost it. Complaining to the managers for months never got anything done so at the end of the night I got a screw driver and removed all the outlets and left bare hot wires hanging out of the wall on all the outlets near the band area. Wish I could have seen there faces when they noticed the next day :twisted: and yes they finally hired an electrician and the problem went away.
If you had that much spare time on your hands, it would have been safer to wire the outlets correctly while you had them apart. BUT that would also open you up for liability.
While I agree with the sentiment in general don't do stuff like this... Safer to put gaffer tape over the outlets with skull and crossbones inked in with magic marker. Maybe squeeze some 5 min epoxy into the outlet holes, so they are unusable.
If people ignore the warning at least you tried. Sabotage in the interest of safety is still sabotage and exposed hot wires is not exactly safety first.
Unfortunately, Gene's stunt does not insure that the nightclub will properly attend to wiring problems, the same idiot that miswired the system in the first place may be called back to do the repairs.
