What I have been able to do is conjure up a box that will accommodate both the B & C and the Ciare however you would need to change port lengths as the LF response will vary between the 2.
I'm going to attempt to outline the differences between these two candidates.
The Ciare will extend down to 53Hz @ -10db and has a 3db down point of 63Hz.It will maintain it's full 350watts electrical power down to 61Hz.
The B & C will extend down to 69Hz @ -10db and has a 3db down point of 81.1Hz. It will maintain its full 350watts electrical power down to 85 Hz.
Neither exceed their x-max at full power in their usable pass band.
Efficiencies are nearly identical as well as are Group Delay and Phase response.
The box size for both is 1.52Cu. Ft.
Vent air velocity is nearly identical.
That pretty much covers the low end.
Now for the HF sections.
In it's favor the B & C has an exponential horn attached but does not list what frequency the horn effectively loads to.
I dont know if the Ciare has a horn attached or not as I can't find a pic showing the front side of the driver but I'm thinking it probably does not as the marketing dept would certainly have been all over that in the .PDF.
The B & C also includes some polar's which is very helpful in knowing what you can expect when you move side to side from the box.
The Ciare lacks this information as well.
Recommended crossover point for both is 1.2K.
AES Power handling is 110W on the Ciare HF section and 80W on the B & C HF Section.
Both look to have some peakiness above 5K which tells me the manufacturers have chosen not to smooth the hell out of the charts.
Freq. response is nearly identical with a slight edge to the Ciare up at 20K but that's really nothing significant to me.
The exit diameter of the Ciare is 1.4". The B & C does not list the exit diameter or FS of the HF section. Looking at the impedance charts I'm guessing it's as FS around400- 500 and also a 1.4" exit driver. If anyone knows for sure about this please chime in.
While I somewhat agree you can cross the B & C at 1K I also think in order to do so you will need at least an 18db network but it will be at reduced power.
You can probably do the same with the Ciare and it does look smoother between 500-1.2K then the B & C. I think with the right network both can be crossed at 1K. I would be in favor of a tungsten lamp to help keep the HF section out of trouble at war volumes.
The B & C HF is more efficient in it's usable passband and the Ciare efficiency chart certainly does not match the written specs on the HF side from what I see. Looks to me more like 102db@2.83v@1M =/-5db not 109db@2.83v@1m,+/-1.5db?
My Price on the B & C is $462.00 US.
My price on the Ciare is $410.00 US.
I have no idea as to reliability of either of these two units.
