Re: Desparity in specification: PRX618S-XLF vs VRX918SP
SRX718S and VRX918S both use the 2268H (same as HPL) which is a single coil, 8-ohm driver
VRX819SP and PRX618S-XLF both use the 2268FF, which is a dual voice coil driver with each coil being 2 ohms
AFAIK, the PRX618S-XLF uses two 500W amps, one on each coil. I'm not sure how the VRX918SP gets its power, but I kind of assume it's one amp with the coils in series.
All this yapping got me interested enough to try and look this up.. It looks as if the VRX918SP and PRX618S-XLF both use the same driver, but unless I am missing something it is not the 2268HPL (also possibly known as the 351210-003X) as the SRX series uses. Rather, it is the 364537-001X. Although according to this, the VRX918S (NOT the VRX918SP) uses the same driver as the SRX series (351210-003X). Are they interchangeable?? That is between you and the JBL gods.
