Hi All
So I have been given 4 x B&C 15ps100, 4 x B&C 15ps75, 4 x P Audio SN15mb and 2 x B&C DE45 on B&C ME20 horns. All these drivers are brand new still in boxs (YIPPEE).
I have made quite a lot of various boxs and so am confident in the building part. I have already decided to do this all active.
I immediatly thought that a set of 2 x 15 and horn tops using the the PAudio units for the low mids section and turn the rest of the B&C drivers into subs so that would be 4 x single 15 subs pe side.
Then I started thinking of ways to make the pa more PACK freindly for cars and the like and thought maybe i could cut the tops into separate boxs for each component which would allow the pack to be more flexible depending on vehicles being used for transport. Remebering this will be for a Pub Band, and also thought it may be more flexible for various gigs instead of always haveing to use the 2 x 15 boxs could only take 1 x 15 low mid and two subs aside if needed.
I am also curious as to what you all think of whether the Subs that i have loaded as a single frontloaded box would play together ok considering they are two different drivers.
Any thoughts suggestions and ideas welcome.
Cheers Dave
Cheers Dave
