Literally the best $20.00 I have ever spent for PA gear was this:
I have all the guitarists I regularly work with "trained" to put their amps on this stand as soon as they walk on to the stage. It points the amp at their ears (like a wedge) and reduces their stage volume to where I can actually get them into the PA. I use a long gooseneck on top, which also saves a mic stand.
-Mark
...If there's too much sound coming off the stage, get plexi baffles...
I once talked a rock band into turning their guitar amps around, facing them toward the rear wall, (including the bass rig).
As much as possible I try to keep the front line wedges to vocals only. When I only had 4 monitor mixes my standard was one mix across the front with vocals only, one for the drummer and a separate sidefill mix on each side to feed instruments into. As someone else said, primarily for people to hear the folks on the other side of the stage but I will add some of them if they really want it.My original concern with this thread was, too much sound (instrumentation) in the monitors. I was trying to clean them up for the sake of clarity, but guitar beaming is a problem too.
-Mark
I think that the biggest issue is that directly on axis at close range a guitar amplifier (especially a distorted or bright country twang) is a pretty nasty beast. Put it in a 50 by 100 room and it will unfortunately sound like that to anyone directly on axis for the first 15 to maybe 25 feet. After that anyone off axis or further back in the room will hear an integration of all the sound coming off the cabinet and room reflections. So 5-10 people (and potentially a microphone) who put themselves in the line of fire will get a sharp nasty sound and everyone else will get what the guitarist was intending (provided they have a clue and know what they are doing). A good guitarist is compensating (I don't like playing with a Fender combo at my feet but I know what will be different about the sound and adjust the expectations at my ears) in what they hear so that what goes into most of the room is what they are trying to achieve. Simple numbers game. Do we cripple the sound or musician so that 5-10 aren't subjected to a harsh sound at the expense of everyone else in the room? Or do we take away the guitarist's control of what they sound like and turn it over to someone who may or may not be familiar with the musician's (the person the audience came to hear) intent so that they can produce their opinion of a good sound into the rest of the room through the PA?
So what happens if he has a vocal mic and moves off to the side?...exactly! Chaos.
Personally, in a club situation...or any situation...I think an amp behind the player facing ANY audience members is far from the best move. Put the amp on the side....the whole band will hear you AND hold you responsible for staying in context with the other players.
Yes; it's my first instrument, although my main instrument is drums.Do you play guitar?
Amp stands don't make the amp any closer, they take a directional device and aim it on axis to the player so that he can hear the actual tone and volume their amp produces. Most guitarists that place their amp on he floor are used to a hi's-rolled-off, muffled sound and don't realise how loud or bright their amps are to most of the audience. I haven't had a guitarist yet who hasn't turned down their amp volume after it has either been placed on a road case or tilted back on an amp stand.There are some who don't connect their hands to their tone who can deal with the unnatural closer range sound of these stupid things, just as some folks can mentally compensate for the muffled sound of their amp on the floor.
Good thing Miles' quote doesn't apply to me, then. I spent 4 years in Music School at University and College, then spent the next 15 years playing and teaching professionally before getting into live sound, which I done full time for the last 20 years mixing 150+ shows a year. If you'd like to hear my playing, here's a link: https://soundcloud.com/markoakley/little-drummer-boy . I'm playing drums and bass, programmed the piano and brass and also arranged, recorded and mixed it. My daughter is playing flute. You play drums too? Great; why don't you post something you've played on?In my book it's a clueless, no-playing (to use one of Miles' terms) soundman thing.
Plexi baffles will certainly cut down the sound of the amp to both the guitarist and the audience but will also change the tone the player has (presumably) worked on. Isn't there a simpler solution, like aiming the amp so that the guitarist can actually hear the volume and tone he is producing? Many small combo amps come with swivel side-arms just for this purpose. And I never suggested that the amp be aimed at the guitarist's vocal mic (if he sings). My favorite position would be side-fill.If there's too much sound coming off the stage, get plexi baffles.
Sorry, Steve, but you're coming off as the hot-headed amateur here. I'm responding to real life problems with actual (and obvious) solutions that I've encountered in my 20+ years of live audio as well as 15 years of live playing. Next time be sure you know a persons experience before calling them controlling, amateur, clueless, and non-playing. Real pro's let their work speak for them.just another controlling amateur who's read too much internet.
There is not always room for baffles and a dangling cord can easily knock them over.
I think I've tried just about every remedy for guitar-burn in the audience. Raising or tilting it up tends to send too much guitar directly toward the vocal mic. Cross-firing guitar amps seems to work well, but can cause problems for a vocalist standing center stage. I've even seen guitar amps moved in front of the guitarist and tilted up like a floor wedge, but an open-back amp still spews volume into the audience.
I once talked a rock band into turning their guitar amps around, facing them toward the rear wall, (including the bass rig). The reflected sound was dispersed nicely and seemed to eliminate all beaming problems. (Even the bass player said that he could hear his own rig better). The guitar's mid-range and high-end could still be heard and stage volume appeared more under control. It was one of the easiest small club rock shows I had ever mixed because I now had full control of guitar volume in the audience area. As a soundman, I really appreciated the results. But alas, the guitarists didn't like it for reasons they couldn't convey. It seems they just didn't want to let go of conventional methods.
A technique I like is to use my guitar amp AS a wedge. ...
A technique I like is to use my guitar amp AS a wedge. I saw Frank Gambale do this several years ago - his guitar speaker cab was placed downstage, tilted back and aimed upwards directly at him, right next to his monitor wedge. This arrangement has a few benefits:
It points the amp at the null of the (presumably directional) vocal mic, if present, rather than at its business end.
It gives the guitarist maximum 'Me' without blasting bandmates or audience.
It aims the icepick at the player, who might then decide to make adjustments to compensate.
It places the amp's controls (if a combo amp) within easy reach to facilitate and encourage those adjustments.
This, of course, assumes there's PA and tech capable of conferring the amp's tone to the audience without any 'direct reinforcement' from the amp itself...
Give that man a cigar!
