FYI: Midas 2.3 Firmware Update
Kevin Hayes
49
Brooklyn
Maybe I'm out of the loop, but Midas still has V 2.1.02 listed as it's latest firmware on it's webpage. After a Pro1 crashed a show I was told "you should be on 2.3". Here's an excerpt of an issue addressed from V2.1.02 to V2.3:
System Kernel - Improved stability of Kernel while writing logs - in extreme cases this had been seen to cause surface lock up.
Here's the direct link to get the firmware.
http://mkt.ftpstream.com/list.php?popup=1&wid=bhr1s9ja
-Kevin
Re: FYI: Midas 2.3 Firmware Update
Hello Gentlemen,
I am Kyle with MIDAS and KLARK TEKNIK in Las Vegas, NV.
The website update issue has been addressed. The off line editor is being updated as I type. The most current firmware is 2.3 REL-51.
For all versions of PRO series desks the addie is mkt.ftpstream.com
Hope this helps, thanks for your concern.
Best Regards,
Kyle Chirnside
Manager, Customer Technical Support Professional Division
MUSIC Group
MIDAS KLARK TEKNIK
Hello Peter,
Our Reps, in the US markets, receive a tech bulletin from our CARE and Customer support divisions. Then the Reps send this info to our end users. I understand that the website is a worldwide medium that anyone can access, and it would be beneficial to have the updates visible. I will raise the awareness of this through my channels to help any new product, or firmware update. Thank you for your suggestion, now to provide a solution.
Best Regards,
Kyle Chirnside
MUSIC Group
MIDAS KLARK TEKNIK
