Hey folks,
Just received my SL16 and a 260. Unfortunately I haven't had any time to mess with them, so I will have to do everything when I get to the venue later today (typing this while sitting in class ).
I have had a couple of minutes here and there to try to figure out how and what to use to set the gain structure. I tried to use a 1/4" to xlr cable straight from the iPhone to the board, which works fine in the first couple of minutes, then something happens to the signal. When I play music, it gets this effects type sound to it, and the vocals are almost faint, and can mostly hear guitars. The signal drops by about 10db as well. I have switched adapters, cables, headphones, with no success. (I'm listening to the signal through the solo bus and headphones btw)
Maybe I'm doing something wrong. What is the best way to feed signal to the SL for gain structure? Should I use a DI in between the two devices? I didn't have this issue with the MG32.
