Guitar Amp Modelers
Re: Guitar Amp Modelers
I am not convinced that impulse response is the secret sauce that completely characterizes vacuum tubes, but perhaps it has merit for speakers and box response.Tube overload is complex to characterize the time constants associated with charges floating around inside the glass bottle that dynamically take time to normalize again after a tube is over driven.
But on a live show you can't just stop the band to start tweaking your settings. Sure, you have presets but they can only take you so far...
Playing guitar with stomps is just like mixing sound on a desk. You can't just use a preset to mix a band and leave it there because you need to adjust to the current playing due to different factors at that specific time...
(snip)
And this is why I think that most modellers like, axe-fx, line6, boss, etc lacks live. Not because of how it sounds, but the way how many of us want to interact with the tools at hand while performing.
This all sounds quite alien to my experience. I'm not sure if you're speaking of bar or garage bands, but in pro bands, the guitar player is not "tweaking his sounds" while performing, he's busy playing the show. Often players don't even switch the patches themselves, they just let their guitar tech handle that. Honestly, I have never seen a guitar player constantly adjusting his sounds while performing; maybe at soundcheck, but never during a show. He's gotta play the show and entertain the audience. Making changes to his sound (other than volume or another adjustable effect like a wah-wah) should be done in rehearsals and soundchecks. Constantly adjusting and tweaking while he's performing I would consider to be very unprofessional.
I believe you are correct. If it were that easy, people would have been doing it years ago.
At any rate, the Kemper appears to have done a pretty good job of mimicing tube amps that are mic'ed into a PA. That is to say that while you may be able to tell the difference between a Kemper and a powered speaker and a real tube amp in open air (although I hear they are quite close), it is nearly impossible to tell the difference between a miced tube amp and a Kemper that is DI'd into the PA (at least it was for my ears).
As I said, if you get a chance to fiddle with one, I recommend it. It is such an improbable proposal for anyone to say a digital creation can sound as good as a tube amp that it really requires first hand experience to make the case.
Andrew,
I agree. I have all my performances setup way ahead of time. My boost for leads is always 5db above my rhythm level, and each patch is normalized in volume compared to all other patches within a song. All of this work is done when I first work up a song. I do some recordings of practice to see how the guitar sits in the mix to make sure it is OK, but I never touch my guitar rig at a performance other than to change patches, patch groups, or punch up to lead.
I have played with many a guitarist that fiddle with their sound in a gig. It is always a mess (at worst), and a pain for the soundman (at the least) to keep the mix together when they do this.
Absolutely correct Andrew, it's a huge rookie mistake to not have your amp in good running shape and your pedal board setup and working properly. I have never tweaked at the gig. The problem is that no matter how many people ask you for tips, most of them either don't listen or just can't grasp the concept. Sound check for my guitar rig usually takes about 10 minutes.
Modeler's are OK for many things. Bass, horns, drums, piano, organ, but guitar is just one of those things that is extremely hard to model. The move to sampled sounds has given modeling a chance to catch up, in particular with acoustic and nylon guitars. Clean electric? Not so much. I know someone with a Kempler (did I spell that right?) who is going to stop by when I'm feeling better, so I'll reserve my opinion.
What I believe JR is eluding to are the harmonics, 3rd and 5th order, that are created and part of a tube driven amplifiers tone. IMO impossible to create with a 3 legged dummy. Add to that the reaction of a tubes plate as voltage sags within the circuit, the reaction of carbon comp resistors, capacitors of different types, etc. and I don't see how it's possible to replicate that sound and that feel with a chip. Completely distorted tones maybe, but clean, no way. When I walk up to a modeler , slap it on the top and here those springs bounce, then maybe.
It's all replicable, Bob. It all has a formula and if you know what that is, you can emulate anything. Things that you mention, like the power supply sag, have been modeled accurately in the Axe-FX. The caps, the transformer reactions to the speaker, the negative feedback, bias and other tube voltages are all emulated. Have a look at the settings and how they function in the wiki. Check out what Cliff (the inventor of the Axe-FX) writes about some of the parameters in the Axe-FX. It seems that he knows a lot about how guitar amps work.
So, I think the difference that people may "feel" will be the interaction between the speaker and the pickups on the guitar which is difficult to emulate, and would definitely require a speaker in the room and a certain level of audio coming from that speaker.
In the end, to me it's much like the battle between the turntable and digital audio camps. Many will never give up the sound of their records for the convenience of the digital format. So, if you just need one amp sound with a few effects, and are most happy with that sound, bring your amp and pedal board. If you need lots of sounds and want less weight to carry, need consistency in your FOH sound and repeatability, a modeler is a great solution. People that use digital audio and are happy with it are not going to be able to convince record enthusiasts to switch, and vice versa.
The harmonics and natural tube power sag and bounce are all there with the Kemper. Hearing and playing one is the best way to be sure.
Hope you are feeling better soon Bob.
There has been a great deal or work done on tube mimics. Peavey was an active participant in that fox hunt and IIRC got a patent or two on their technology, while there are plenty others.
As you well know the sound character of a tube guitar amp involve multiple moving parts. Beyond the static transfer function characteristics (like distortion) there are dynamic mechanisms going on inside the tube. That I am probably not describing accurately but when you significantly overdrive a tube the internal charges can shift around inside the bottle and alter the tube behavior, until that rogue bias state decays and returns to normal.
While not exactly the same thing as this thread is talking about I have heard Peavey solid state amps that were designed to mimic tube amps that sounded very good to my "not a guitar player" ears. In fact and I have shared this before, Peavey did a single blind A/B demo at a NAMM show (probably 15-20 years ago now) where the majority of players could not tell the solid state amp from a real tube amp. A nice thing about the solid state tube mimics is you can play games with adjusting the special tricks. The saturation effect could be dialed down to give the screaming overdriven sound at modest, less than ear splitting levels... Some real tube guys use a tiny amp to get that effect or variac down a bigger amp. Another tube mimic is to artificially alter the amp output impedance to increase interaction with the speaker/cabinet. Doing this in solid state allows you to not only make this variable, but tweak HF and LF amp output impedance separately. Of course this becomes too many knobs to turn for the typical guitar guy, I could imagine fun in the recording studio.
By definition a solid state amp will never be a tube amp, but we have the technology to get pretty damn close, and for feeding a PA close enough.
On a related note I tried to get one of the junior guitar amp engineers at peavey interested in making a solid state tube mimic that was actually better than a tube amp. My premise was that using extremely low noise JFETs and transistors in a tube mimic circuit could make a tube-like amp with lower noise floor and wider dynamic range. AFAIK he never took the bait and pursued that. :-(
IMO for many the attraction to tube amps is more a fashion statement than about absolute sound quality (not all tube amps sounded good), kind of like like the old school audio-phools and their vinyl.
Maybe it's similar to the difference between modern steel roller coasters and old fashioned wooden ones.
The steel coaster probably goes faster and is scientifically designed to be smooth and safe, while the wood coaster provides much of its thrill because of the creak of the wood structure flexing and the bumps and rumbles of the less smooth ride.
(just a thought that occurred to me).
carry on
Like you John I have also followed the transition of transistorized amplifiers to todays modeling amps wondering if some day the technology would come to a point where the replication of a complex tube circuit could be produced using a DSP. I'll agree that the latest technology available can almost faithfully replicate most of the more well known and desirable amplifiers. A VOX AC30, Fender Deluxe Reverb, Marshall JTM45, etc. have been around long enough to be recognized instantly. That being said, replicating the sound is one thing, but replicating the feel which translates back to the player is another matter entirely. That feel which translates back to the guitar can be a subtle as a harmonic or the amount of perceived pressure used to bend a string. This is what's lacking in modeling amps IMO, the same thing that was lacking in the first transistorized amps of the mid/late 60's.
Now, with all that being said the use of a modeling amp is becomes more acceptable depending on the style of music played. Mimicking stomp boxes has never been much of a problem because they are an added effect and with few exceptions based on the reaction of some 3 legged dummies, a few diodes, or a single chip. But even those emulation can be inaccurate. As an example the SM57 of the stomp box world, the venerable tube screamer suffered from the use of newer technology when the tone and response characteristics changed as the latest chips were manufactured to tighter tolerances, enough so that sales dipped and Ibanez felt compelled to release a re-issue using specially manufactured loose tolerance chips. To someone who is not a player, or a player with no experience with these older units, the difference may go unnoticed, but to most players the sterile sound of the new chips meant everything.
I have had a chance to try the Kempler and the Fractal modelers, and I'll have to say they are amazing. The emulations are for the most part spot on and just fine for that person who needs something to cover a dozen styles of music, or for someone who wants to replace their stomp boxes. I found some differences, or failings if you please, in that emulating a small open back cabinet with a D120 in it compared to replacing a D120 with a clone speaker. Close but no cigar. I also found it difficult to emulate a number of compressors, specifically a Ross compressor. Delays and reverbs were fine, but the reverbs didn't come close to anything I've ever heard coming from any Fender with the word reverb attached to the name. I did like the Leslie emulation I was able to dial up and just about everything else sounded just fine. I didn't feel either unit was very touch sensitive. The best experience was when I pushed the modeler through my board, through a small QSC amp, and then to the cabinet of a Super Reverb loaded with Warehouse 10" speakers (4ea.). Thanks to my friend Tim who took the time bring the unit over for the listening test and who put up with my constant requests for changes to his settings.
John, Your not so good ear was spot on. Many of the Peavey transistorized amps fall into a small line of acceptable solid state amps. It's no secret that a good number of amplifier manufactures shot themselves in the foot after turning to the 3 legged dummy as the replacement for the tube. However, Peavey was not one of those companies. Put them in a category with a couple of the old Gibson amps, LAB 5, Roland JC120, or SG Systems (hybrid). Many is the country stage I've seen where Peavey amps rule supreme when set beside a Twin Reverb or equal, a statement that holds true to this day. Ask yourself why BB still uses a LAB 5? There are exceptions to every rule.
For me, and with the style I play, there is no modeler made that can replace my beloved Fenders, and very few boutique amps for that matter. And after I blueprint an amp, well nice try. But that's not to say modelers don't have their place, and what's one old fart got to do with their acceptance. Not much I would think. So, maybe before the dirt nap when I can't pick up the old iron, maybe then will be the time for me.
@ Bob... thanks for the kind words about Peavey amps but that was kind of like the family business so they had to get that right. As the legend goes, young Hartley wanted to play guitar in bands and he was able to build his own amps for himself and his bandmates, after getting kicked out of the second band that he outfitted with amps, he decided to skip ahead to the end game and just build amps for sale.
I shared lab/office space with peavey guitar amp design engineers a few decades ago and one important observation, they were also active players in local bands. So they knew how the amps were supposed to sound. I recall how painful it was to listen to the previous bass amp engineer who didn't play, wank on the amp he was working on... How can you design an amp if you don't play? It's a musical instrument, or part of one.
I do not consider myself qualified to judge how good the standard amps are/were, if the lads could make Eddie Van Halen and many other professionals happy, that's good enough for me. My specific comment was about the trans-tube series that was new back when I was working there (decades ago) and they were a dedicated tube amp mimic, that in my judgement did not completely replicate a tube amp, but was able to convincingly recreate a number of the euphonious tube amp sound characteristics. (YMMV).
One thing to remember about this discussion I do not pretend that these (new modelers) are exactly like tube amps, they only need to sound like a tube amp playing though a PA system (for this thread). I have had many discussions with the lead amp design engineers and have a passing awareness of the many obscure variables involved in characterizing a tube amp path (+transducer sound + box sound + etc).
So enjoy your old iron when you can, and it is just progress that modern modeling technology is getting better.
John,
That would be my assessment as well. Creating the sound out of the PA is where the new modelers excel (also recording).
As for the feeling, the interplay between the guitar and amp can only occur through the movement of air (in order to do it properly). A monitor at a reasonable volume level is needed for this IMHO.
@Bob,
I am glad you had the chance to get the feel of some of the best digital guitar amps out there. It is hard for anyone to give up a Fender clean once one has played on one ;)
The best results I have been able to obtain with my Kemper came from using a Yamaha DSR112 as the speaker. Also while the built in rigs were very good, I found that the profiles commercially made at "The Amp Factory" were a cut above and improved the sound of the device considerably.
I think that there may be a difference in open air, but that it is difficult to tell the difference once you put it through a mic and a PA as JR suggests.
In my IEM's it sounds wonderful :) :)
The difference is most apparent if there's a real amp present. By itself a modeler can sound "fine", but none of them will stand up to a direct comparison to an analog guitar amp.
Out front, once miced and put through the PA, it has been my experience in direct comparison to a really good tube amp (VHT (the old ones, not the new ones after Steve Fryette sold the company name), that this is not true.
In open air, the amp and speaker make a big difference.
This is key. The modellers are modelling not only the amp and effects, but the speaker AND the microphone.
Real comparisons have to be done comparing the modeller output to a recording of a mic'd amp through a PA or reference monitors. In this scenario they compare very well to each other.
People are still not convinced as I still see players with their amps in ISO boxes 50' from the stage which could easily be replaced by a modeller.
Much like IEMs, most hate them until they've gotten the right moulded ones with a great mix going through them.
It's the analog vs digital argument all over again.
I understand tech fairly well, but interfacing with one of those modeler amps is still as enjoyable as going through a TSA pat down.
And if you're playing a jam or open stage, a Fractal is like taking a F-1 car to a stock car race. Impressive, but wrong tool for the job
