Buying such parts in small quantity may cost a little more than that... The issue is the physical integrity of the PCB. Most experienced amp designers use oversized, several watt resistors for those emitter degeneration ballast resistors, precisely so they don't burn up from common faults. The typical failure, is a power device short circuited, putting many watts into those parts short term until a fuse or breaker pops.
If the circuit board is not burned to the point that the foil is lifted and unusable, you should be able to simply solder in new resistors. I am not familiar with seeing only the resistors fail,,, but usually they look worse from power device failure, so who knows? I am certainly no expert on fixing Crown amps.
If Moby is around he should know... but if you have lost a power device or more, it will be more than a few bux parts cost. You often can't tell a bad power transistor from just looking at them, but common failure modes are dead short between collector emitter, and a second common failure is open base. So a VOM can tell you pretty quickly how serious that repair could get.
