Line array for 1500 cap venue
Re: Line array for 1500 cap venue
That is going to be extremely difficult for audio alone, let alone lighting. You are going to need to buy used
I've already advised them of that. That's why I'm starting relatively early... it's going to be 6 months before anything gets hung, so that gives us time to have feelers out for a used system if we go that route.
Since it is a new space being designed, also consider power, conduit/cable paths, rigging loads, etc.
All true, but for the scope of this thread I'd like to keep this focused on main PA only. I didn't want to write a book on what I've done so far, nor expect a comprehensive guide to designing a venue, because everyone's time is more valuable than that. Just trust that most of the things raised in this thread are already addressed. I and others provided a lot of feedback early in the process on power and logistics and their architect did a really nice job. Already met with structural engineer and overestimated our rigging loads. Only thing I couldn't get was a loading dock. :-( But it will mostly be bus/trailer shows anyway and we've even got shore power covered :-)
Basically, I've been sketching PA ideas in a vacuum and really needed some 2nd opinions to see if I'm on the right track or not.
You should visit First Avenue in Minneapolis, a similar size venue to what you are talking about, anybody on your circuit will either have just been there or will be headed there.
You're dead on... The owners visited First Ave and other similar-sized clubs from Fargo to Vegas for ideas. But I'm embarrassed to say I have not even been there... I feel like I've worked every weekend for six years, so I don't even know what's outside of town anymore. A trip would be a good idea.
One of our main venues is a 1200 cap theatre, we bring in 2 over 2 SRX for the quieter shows (ie. most recently Terri Clark), for larger shows we'll bring 3 over 4 (Theory of a Deadman, more recently the Sheepdogs), in most cases we tie into the house system for fills.
I've also hung a few different line array setups in the room, unfortunately they were all compact models.
Running 3 SRX per side may get loud, but it's going to sound awful. Not designed to array like that at all.
"Designed for arraying" boxes would be things from Danley, KF750, and the like. I wouldn't consider KF650 or KF850 to be "designed for large arrays" boxes, even though they are often used as such.
If you're going to do a trap rig, do it right. Same for a LA. Either could work, it comes down to who designs and tunes it.
1500 people in 2 story building... What’s the room layout look like? What sort of budget do you get to work with? Is there any existing gear?
For local/regional bands and B level touring acts; I don’t think the names on the boxed mean anything, they are more about “I have this many people in my band and I need this many mics with this many wedges”.
Agreed, bands playing clubs are interested in money above all else. Almost any system that will cover the room and sound decent will probably pass muster.
On the list of issues the BE is going to bring up, not enough cabs generally ranks higher than a little bit of coverage overlap, mobile work is often a game of making what you have work. I do agree that for an install it should be done right however.
2xKF850 per side should do that space, perhaps with some front and balcony fills, no?
In a small city in South Dakota, probably, but the few groups that bother to advance a show would probably bitch anyway.
They will bitch, but if the club is on a route that makes sense and provides some travel money, they will play.
Since it is a new space being designed, also consider power, conduit/cable paths, rigging loads, etc. and the fact that some permanently installed aspects may have to be approached slightly differently than they would in the tour/production world. The gear itself may change but they may be stuck with the same infrastructure initially provided for a long time.
This.
Things like conduit and cable paths, sufficient power, adequate rigging capacity in acceptable locations, and sufficient back-of-house space are relatively inexpensive to add during the construction phase, but very expensive and difficult to add later. Also things like acoustical design and reasonable load-in paths. These all get you much more bang for your dollar than buting a PA that you can probably rent or lease initially until proper funding becomes available.
I think you mean "just enough". As long as they're modern, pretty high performance 18s too.
I typically use 4 VR218's per side in a room over 200 ft deep and over 100ft wide. They are aux fed and BE's rarely ever push them to unity gain. I'm just guesstimating that maybe a room about 1/4 of the size could get by with less :/ but as they say "smoke em' if you got em."
How does "unity gain" have anything to do with max output?
Especially when you're talking about subs. Hard rock, metal.... anything with an "808 drop" fixation... there is NEVER enough sub.
My thoughts exactly.
Here's what I recently brought in to a 1600 cap club(which actually had 6x VT4888's and 4 SRX subs per side too)
attachment.php
Yep. 16 dual 18's in a 1600 cap club- it was very enjoyable. :) 117dBC(104dBA) average, with peaks well over 126dBC(108dBA).
Any acceptable PA in a 1500 cap club would be as follows:
Line arrays:
-6 d&b Q1 & 3 d&b B2 per side.
-6 VT4888's & 4 VT4880A(SRX728 substitute) per side.
-6 EV XLC127 & 4 EV X-line sub per side.
-6 EAW KF730 & 4 SB1000 per side
-8 Nexo S12 & 4 Nexo RS18 per side
Trap Rigs:
-3 d&b C4 Top, 3 d&b C4 sub flown, 3 d&b B2 sub per side.
-4 EAW KF850/KF650 flown per side(2x2), 4 SB1000's per side
-2 EV XF, 1 EV XB flown per side, 4 EV x-line sub per side.
-3 Nexo M8, 3 B1 flown per side, 4 S2 per side.
And that's all I can think of for now. Any of those systems, as long as they are properly deployed, properly powered(with controllable zones) and have proper fills will kick ass in a 1500 cap room.
In a smaller market, though, what's realistic? We can't all be the 1400 cap 9:30 club in DC (with 8 Js per side and 3 B2s per side).
I spent many years touring clubs your size, typically lucky enough to be bringing my own desk through, and while I've been fortunate lately have been touring at a larger scale, I'm sure there'll be a day I'll do some clubs again. I'll be the most happy with a rig that's been well-maintained and properly deployed in the room, be it KF850s, Cs, Alpha, Vertec, and so on and so forth. I came into this industry running production in an 850 cap "theatre" in a smaller market that was one of the big rooms for the town and the small stop for tours hitting larger rooms. The rig was nothing spectacular, but was well maintained, well suited to the room, and sounded pretty decent. It was "fine" on the sub count, but could have used a little more, so I definitely recommend over-building the sub count.
I'm with a lot of other people here in pointing out that a rig is more than just the boxes that get bought. There's processing, amps, consoles, wedges, mics, stands, cables, subsnakes, power distribution, and so on and so forth.
126dBC is inappropriate and irresponsible as you have damaged peoples ears and thats even too loud for people with hearing protection.
to the original poster, a nexo alpha rig would do well in that space for a reasonable amount of money. or if you are set on a line array, what about an ev x array. Its no ones favorite box but its also a box no one will kick out of bed. X array systems can be had for very reasonable money, leaving you more room for a board that will have to get moved less often because someone doesnt accept it.
Have a look at the Fletcher Munson curve. 126db at 30-40hz is no where near as bad for you as 126dB at 2k...
I'm all about good n' loud, not hurting people. My average LEQ over 1 hour over the past 10 shows is 102dBA. Show dynamics and powerful low end is all part of the experience. Hurting people is not. :)
