I can't decide what to do, and why I am getting the results that I am. (so this all could be me!)
I have (2) different subs that I use:
EV QRX218s - powered by a QSC RMX4050HD (1-per channel, 1300w @ 4ohms)
Yorkville LS801P - Active sub with a 1500w Program powered amplifier (which I assume is really just 750w?)
I use two different systems because people hire me alot of times with there eyes (weekend warrior type gigs).
Large system is (2) EV QRX218s & (2) Peavey QW3f
Small system is (1) Yorkie LS801P & (2) RCF ART325i
People pay me more for the *larger* system because it looks more "Rock & Roll" to there eyes, even though I tell them that my smaller system is just as good if not better.....but they don't believe me.
What I need help with is I just don't know what to do with the EV QRX218s!?
On a 1 to 1 comparison the LS801P destroys the QRX218, this in my mind should not be happening.
The EV QRX should be a much better sub in terms of output and sound quality, at least that is what my bank account has told me.
Side by side in my basement I switch back and fourth between the two, bringing the RMX4050 too just flicker the clip lights on the amplifier, I do the same with the powered LS801P just getting the yellow limit light to flicker.
The QRX218 should be moving more air as there is more cone surface area, but the LS801P is clearly the winner.
Both in output and bottom end.
I am using in my test the QW3f high packs with both subs, I have both subs crossed at 90hz by an Ashly XR1001.
My EQ on the QRX218 is completely flat from 100hz down, when I switch to the LS801P I actually cut 6db @ 80hz to get rid of the annoying boom sound the sub has.
WTF am I doing wrong??!!
I am looking at larger amps for the QRX subs thinking they are not getting enough power, but even at that, I don't know if it will make them any better then the LS801P seems to be.
Am I missing some EQ or more power solution that will help the QRX? or is the LS801P just a better sub?
Please help!
Vinny
Please help!
Vinny
