Hi, does anyone have a schematic crossover for the BMS4593ND 8 / ohm driver. Thank you
Filling the whole chamber would impact the air flow, making the drivers heat up faster. I would avoid that. Do put some foam on the free surfaces though, as in, the sides, top and bottom of the chamber.one more question about the damping: Is it supposed to be applied on the sidewalls of the chamber only? Or should the whole chamber be filled? What material did you use? sonofill? or soundabsorbing foam mats?
I am about to finish the cabinet build and totally forgot about the dampening.
Don't ask me why, but at the time I didn't realise I could order the 12" as 4 ohms and wire in parallel to make an 8 ohm system
Not quite. Typo perhaps?
Yup, that's an option too.Perhaps I could power with a cheaper sub amp with simple crossover filters and power the tops with a suitable DSP 4-channel amp for tops.
Also just confirming when you note the nominal power for each speaker is:
12NDL76 - nominal 400w per speaker - I am gathering you quote 1600w as that is 2x 800w of one group of 12"
= 2x 1600w channels needed
DCX - nominal 110w + 80w = 190w per group
= 2x 380w channels needed
Correct?
Stupid fun question time to build understanding:
1) is it possible to wire the DCX coaxial in series somehow from the amp so that it becomes an 8 ohm circuit powering both coaxials ?
2) I read somewhere that bridged amp outputs double their desired impedence i.e. 2 channels bridged that are rated for 2x 400w 4ohm individually would now be 8 ohm 800w when bridged ? Is this true?
3) If I power a 16 ohm circuit of the coaxial which is also quite sensitive with an 8 ohm amp say 400w channel, is it allowable/suitable to think of the wattage requirement as increasing / doubling ? So something along the lines of an 8 ohm 800w channel is necessary under this application.
4) Or under this same silly philosophy , that powering the 16 ohm coaxial with an 8 channel 300w amp would be suitable given it is more sensitive and the volume reduction would be suitable (and run 12" parallel as 4 ohms)
+++ on everything David said. I habe built the same combination, only difference is theb12NDL76 are wired in parallel -> 4 Ohms.Hey guys, haven't posted in a while but have some progress pics to share when I get them off my phone. Proud to say we've finished building our own pair of PM90's - but I have an important question to ask regarding amplification and worrying that I have royally messed up here.
Basically, I have ordered and built the PM90's as:
2x 12NDL76 12" 8 ohms wired in series @ 16 ohms
1x DCX464 with passive crossover - 16 ohm
Currently are wired to run on one NL4 1+/1- = 12" series , 2+/2- = DCX via passive crossover
I measured the ohms with meter and they are coming up as ~7.4 ohms. I believe this is considered normal because they are measuring DC resistance
Now back to the issue at hand - I realised I may have messed up in building this as a 16 ohm system with regards to finding suitable amp/power. From specs and information in this thread, I realise I need 400W for the 12" and 160/220w for the DCX (we'll leave processing aspect to a bit later) so,
1) What power amplifier do I actually need? Does it need to be a 16 ohm 400 watt 2 channel amp for mids and 2 channel ~220 watt amp for DCX? Or can I run the whole tops system on a 4 channel 16 ohm amp @ 400 watts per channel
i.e. https://www.labgruppen.com/product.html?modelCode=P0CPE
2) I know I can still safely but not efficiently amp it with an 8 ohm amp still, but if I do - does the wattage need to be above the continuous watt recommendation to make it work ?
i.e. https://proaudio.com/content/Documents/Specsheet_Linea Research_48M.pdf
< - 48m03 or 48m06 being 400w/750w per channel ?
3) If I run it on an 8 ohm amp - will it sound fucked ? / have large loss in max volume achievable - I read somewhere you will only lose out on 3-6dB of max volume achievable by high mismatching amp and speaker impedence
4) As a learning question - Is it possible to run the whole top system + 1250w rated 18TBX100 subs on say.. the linea research 48m10 @ 1250w per channel
Sorry that my understanding of matching amps is complete newb level. Biting nails here, and feel stupid.
Yes, it is easing to know that that is the right way of doing things - this is my first build so I thought all had to be matched. Thanks for the tip and reassurance on amp choices.+++ on everything David said. I habe built the same combination, only difference is theb12NDL76 are wired in parallel -> 4 Ohms.
To give you an example, I am powering the pair of DIY90 with a FP10000q. At 16 ohms for the high section, it has enough reserve (660w power). With [email protected] for the mids, i have enough power for most scenarios, since I dont want to treat them to maximum output to minimize risk of damage. They will still go louder than any standard top i ised before.
The subs are powered with a seperate amp (FP14000).
This is going to sound like a very obvious question, but what is the thinking behind the 16 ohm versions of the DCX464 and 4594 coaxials? They have never struck me as the type of driver which would be used in multiples, and even the 8ohm versions need a disproportionately large amplifier to achieve the required output voltage to drive them properly...
As mentioned here and here, the 16 Ohms version will have less noise. The DCX464 is really sensitive. With the 16 Ohm version, I still get quite noticeable hiss. In PA settings, this is no problem, but for hifi, it would be too loud, imho.This is going to sound like a very obvious question, but what is the thinking behind the 16 ohm versions of the DCX464 and 4594 coaxials? They have never struck me as the type of driver which would be used in multiples, and even the 8ohm versions need a disproportionately large amplifier to achieve the required output voltage to drive them properly...
No, you could go with less. 1.5 to 2 times RMS power is a rule of thumb. You want to have enough reserve on the amp to secure headroom. Otherwise, you might too easily drive the amp into clipping. The signal then gets compressed and the speaker likely gets damaged.Yes, it is easing to know that that is the right way of doing things - this is my first build so I thought all had to be matched. Thanks for the tip and reassurance on amp choices.
It is right that the subs need ~2500w each if there are 1250 watt rated ?
Not sure, what you are referring to. Do you mean powering to cabs with one crossover? Is your question, if the 16 Ohms HF + 16 Ohms VHF of the coax are wired in parallel on the FB464 crossover = 8 Ohms impedance for the amp channel?This is where things get weird for me as I've spent a lot of time thinking about this in last 48hrs, and I'm utilizing the passive FB464 crossover. The DCX464 is technically 2 in-phase drivers for HF + VHF, both - according also to website 16 + 16 ohm. If I am powering the crossover itself to both speakers - is this in fact an 8 ohm parallel group of 2 drivers ?
And if they are resistance-matched - they each draw equal power evenly, then should the "program power" amp channel requirement be 320w (220w MF + 160w HF continuous power handling) to suit the more delicate HF driver ?
In response - for example with my PM90 which I figure is relatively standard in using the FB464 passive crossover designed for the DCX464 :Not sure, what you are referring to. Do you mean powering to cabs with one crossover? Is your question, if the 16 Ohms HF + 16 Ohms VHF of the coax are wired in parallel on the FB464 crossover = 8 Ohms impedance for the amp channel?
Those are really quite nice looking!Man, I love these things but wow they're HEAVY!
In terms of sound though, nothing has ever come close to matching them in all the years I've been gigging, and I've used all sorts of speakers in the past! Just wanna say thank you so much for this thread!
