PMA - 60; New arrayable double 12 and horn.
Finalizing the plans. Peter looking for a bit more volume, not critical but would be better with the Ciare. I know I can go taller if need be to get a bit more but can I go any wider on the front bafflewithout noticably screwing with the splay testing and comb filter testing you did? I’d really also like to get that horn centered. Not sure how critical you were on these tests so wanted to just ask the question.
Thanks much.
Sent from my iPhone
You can’t move the horn to the centre unless you make the box wider or reduce the wall angle.
I don’t know how much the array performance is comprised if you do that.
The simple rule for arraying is ¼ wavelength spacing of the drivers centre to centre.
When you look deeper at the problem, the cone does not just radiate from the centre, it radiates from the whole surface. If we had square cones operating as a piston and they were close together then they would couple up to a much high frequency. To get that to work with round cones is difficult because the gap between the drivers on average is too much.
In practice there aren’t too many problems until you go past ½ a wavelength. In this case ½ a wavelength is 486Hz … so we are pushing things – but it seems to work and sounds fine.
The idea behind this box was to build a nice small powerful general purpose 60 degree mid high speaker that could operate from 80Hz up, but design it in such a way that it could be arrayed as two or three boxes a side and have fewer problems than any other general purpose box on the market.
What I did was pushed every thing as close together as I could to minimize these problems. I was thinking of putting a phase plug Nexo style over the 12” drivers, but I don’t think I will gain that much … may be I will try it latter.
If you increase the box size you may need to retune the box to a lower frequency to get a smooth roll off. You don’t want a resonant bump around the port tuning frequency.
Peter, everything else being the same, would widening the front baffle width from your 360mm to 375mm (+7.5mm per side) have any significant detrimental effect on the 25deg/25deg splay cohesion? It’s a comprimise for other factors in my build version of this, however with both LF drivers and HF horn centered on that baffle, I would imagine the negative effects while there due to increased center to center distance, it will be very minor. Everything is a comprimise in this buisness.
Thanks
Sent from my iPhone
Thanks
Sent from my iPhone
Can't imagine 7.5mm would make any noticeable difference Chris.
Thank You sir. Just wanted to confirm. My next post will be that of the build. Pretty excited to get this going. Spent most of today tweaking and optimizing (hence the mm micrometer question). Drivers and horns are in for two cabs, picking up the BB tomorrow. Once the first is done and tested, second third and fourth to go.
The other project I mentioned, is delayed until late Spring as I will be back out in the friendly skies again for a while.
Are those rear ports going to throw mud range back at the stage?
Not throwing shade at the boxes, just curious what the back spill is like.
Peter,
some questions, please take them with a grain of salt or 2
does that goes louder than a JBL SRX 835?
is there a passive crossover for it
or you need a 4 way processor like dbx 260 (Low, MidLow,Midhigh,High) as i can see the HF driver is coaxial, so it is a 3way box
and instead of going with 3 discreet drivers like the 835 you have used a coxial HF
now, is it possible to replace that coaxial of almost 1k dollars with a one way HF kind of like the SRX812
that use the 2432H HF driver
i know that the tuning of the box maybe need to be modified and the ports
you designed a Bugatti like speaker, but i can only afford a nissan sentra or toyota corola
Now i was reading that you talk about FIR processing , can a simple DBX PA or 260 be configured to drive em
or you need something more exotic like a Lake , BSS or XTA
i am not a speaker engineer or builder but i know that your loudspeaker designs are top notch with premium components chosen
and just seeing the graphs i can tell that those are on on par with the most efficient PA speakers on the market.
but efficiency is not free, neither premium components
Peter,
Peter hasn't checked in in a long time, but I can answer your questions.
Yes, the PM-A60 goes louder than a JBL SRX 835 with less distortion.
No.
No, typical HF drivers won't go down to the crossover point needed for the folded horn 12", around 675Hz.
You could use a passive crossover as made by B&C for the mid/VHF crossover, and tri-amp the system from the lows at 80-100Hz, mid up to 675Hz, and mid/high above.
You can get (arguably) over 90% of the sonic performance with a good IIR DSP, FIR processing allows low latency flat phase through above ~200-400 Hz and up, which sounds slightly better.
And if you aren't a speaker builder, you will find it hard to find one that can save you much money when using premium components.
Reactions: Carl Klinkenborg
