Road Case Acronyms
Cole Lofink
NJ/NC
www.sonuspro.com
What are some of the acronyms you guys have on your road cases. Although I would enjoy to see or hear some humorous ones I'm more interested in serious ones. By serious I mean clearly labeled so crew knows whats inside. So the right cases get in the truck and get to the gig.
<u>Heres what I'm using thus far;</u>
PWR-000 (cases containing power cables)
MIC-000 (mic and di boxes)
OBR-000 (out-board racks)
LED-108 (Case 1 containing 8 LED Pars)
Now I need acronyms for my; wireless mic racks, audio trunks, lighting trunks
Consoles are labeled with model number; CX8-244 (Crest X8 24mono 4 stereo)
Re: Road Case Acronyms
I got this 3 letter then 3 number thing going on so it lines up nice in Excel.
How many of each of these do you have? If you only have one mic box... writing MIC-000 is a bit dopey looking to me. If you only have two of them... then MIC-1 , MIC-2 would seem a bit more practical then mic-001.
I know some guys who color code their different systems, which makes it really easy to use them in combination, without the struggle of making sure everything gets back where it belongs. Example... everything in the ''A'' rig is marked blue in some way (e-tape is used mostly) ... the ''B'' rig will be yellow and so on. It's simple, and effective. Then just label the case BLUE-RF, YELLOW-LT.. etc.
I mentioned this on Facebook, so some of you may have seen it, but when putting boxes in to your inventory computer, it is better to use labels that make sense both to you and your customers, when they review the invoice.
What we learned we should NOT do is put it in the computer with its shop name. ''What is a Ye Olde Socopexe Trunke?'' asked a customer recently.
If I remember rightly, ours is something roughly like this:
0-999 = guitar/bass amp case
1000-1999 = keyboard case
2000-2999 = rack
3000-3999 = drum case
4000-4999 = utility case
etc.
If you run out of numbers, you have one hell of an inventory.
Our cases are mainly labeled with what is in them.
DR-1 -> Drive Rack
FX-1 -> FX/Dynamics Rack
PS-1 -> Console Power Supply
EQ-1 -> Monitor EQs
Main PD -> Main Power Distro
Sub PD -> Sub Power Distro
FOH Amp Racks are just labeled 1-24
MR-1 -> Monitor Amp Rack
SC-1 -> Audio Snake
SN-1 -> Lighting Snake
AC-1 -> Audio Power
MC-1 -> Monitor Cables
M1 -> Motor Power
LWB-1 -> Long Work Box
R1 -> Rigging
F1 -> Feeder
CC1 -> Concessions Case
XT-1 -> L Acoustics 15XT Monitors
Arc1 -> Arcs
If you have more than one case of each (which we have lots of), just up the number.
The Band gear that we transport is normally just labeled with a number.
Because our entire rig is a rental package we put laminated labels on each box stating what is inside of it. I have trunks named such things as ''Front Fills'', ''FOH Snakes 1 of 2'', ''Pit Snakes'', ''Mic Stands'' and 26 other equally descriptive names.
I find this much less confusing than any letter and number code. They're fairly durable (they've lasted 430 shows and 15 months so far) and they can be changed whenever you need to with minimal effort.
The locals aren't going to take the time to learn any particular numbering system. In that case best to just say what's in it. The big number/letter help when calling a pack but for contents best to put what's in the case on in in some way. Jake's laminated tags are popular as is gaffer.
We do the whole gaff with sharpie on it.
All cases have numbers on them for the truck pack, and then they are labeled with a big thick sharpie what goes in it.
Weekend warrior (and swamp yankee) that I am, I never saw fit to come up with anything but a plain-English description on the case: Amp rack, FX rack, mics, etc. Just white gaff and black sharpie. Like Jake said, it's less confusing.
Much less confusing. That is, until plain-English doesn't suffice. But that's a whole separate thread. We found these little hand-written labels all over the place after the Tokyo stop.
