Re: Simple sub design
Would anyone consider helping with a box design. I'm not looking to go low with the box. I have double 18 boxes now from PAS MF218. The original drivers have been replaced with eminence omega pro. The boxes are ok but don't always fit my needs. I would like to take the drivers out and build single 18 boxes. What I need them for is live sound. I never do dj work or play edm. The amps I have will deliver 1600 watts to each driver. I tried doing it myself with design software but I don't know enough to get it right. Just hoping someone can give a hand. Thanks
This is way to wide open of a question. And some of the replies are already projecting their needs into the answers.
You need to give us way more to go on, and do way more thought yourself.
So what are some of the priorities?
Size. Footprint. Does the cabinet need to be used to stack other things on it? Or are the mid highs on sticks?
If you are stacking, how tall does it need to be? Does it need a certain footprint for safety? Will it have a cup for a pole?
How will all of this interact with your material? EG, are you using 4x8 sheets? Or 5x5? Or do you have some pieces around you need to work in?
Do you need to meet a certain size for transportation? Truck pack? Trailer pack? Minivan pack?
To all these questions above, Art Welter (one responder to this thread) had an awesome system that was designed to pack in a van, stack to a good height for audience clearance, and be made out of materials that would not have a lot of waste when cutting them out. I have no idea how low it went, (I'm guessing his answer provides clues), but to me the other things were just as important, and very impressive in the implementation.
The first thing my calculator tossed out was 8 cubic feet, one 6" port, 4.33"
The eminence below is 6 cubic feet, four 3" ports, 6.54".
Where do these fit into your priorities?
Regards, Jack
